.NET
Valued Contributor
Prakashdotc
Message 1 of 32 (279 Views)
Creating .dwg file Programmatically
279 Views, 31 Replies
05-02-2006 06:40 AM
Hi All,
How to create a .dwg file with some entity example line, programmatically with c#, can any one help me with example please, thank's
Prakash
Active Contributor
deepa
Message 2 of 32 (279 Views)
Re: Creating .dwg file Programmatically
02-15-2007 09:01 PM in reply to: Prakashdotc
using System.io
File.create("C:\\temp\\ex.dwg");
Distinguished Contributor
eljobe
Message 3 of 32 (279 Views)
02-16-2007 10:15 AM in reply to: Prakashdotc
Can you open that example in acad?
Active Contributor
deepa
Message 4 of 32 (279 Views)
02-23-2007 08:13 PM in reply to: Prakashdotc
Yes.Sure
gilseorin
Message 5 of 32 (279 Views)
02-23-2007 08:22 PM in reply to: Prakashdotc
No, I tested it.
Creating dwg file is good,but can't open.
That's no available.
create .dvb file,.txt file ..... all is working, but can't open.
Active Contributor
deepa
Message 6 of 32 (279 Views)
02-24-2007 02:53 AM in reply to: Prakashdotc
Right Click - >Select that File name - >open
It's working in the txt files and other extension files.
but I test it the dwg file.it's true.i will try get a solution for that.
gilseorin
Message 7 of 32 (279 Views)
02-24-2007 07:08 AM in reply to: Prakashdotc
Imports Autodesk.AutoCAD.Runtime
Imports System.io
Public Class GILSclass1
_
Public Sub EraseObjectsFromLayer()
File.Create("C:\\temp\\MyTest.dwg")
End Sub
End Class
Attempting to open created 'MyTest.dwg' file in the specified path, I meet the message of 'Drawing file is not valid.'
*Paul Richardson
Message 8 of 32 (279 Views)
02-24-2007 08:29 AM in reply to: Prakashdotc
Why would you think that the System.IO knows how to create a dwg file??
wrote in message news:5498917@discussion.autodesk.com...
Imports System.io
_
End Sub
End Class
gilseorin
Message 9 of 32 (279 Views)
02-24-2007 09:39 AM in reply to: Prakashdotc
It's not my thougt, I only follow as you mentioned above.
Using system.io;
*Paul Richardson
Message 10 of 32 (279 Views)
02-24-2007 07:54 PM in reply to: Prakashdotc
I didn't mention anyting above...
Database db = new Database();
db.SaveAs(...);
db.Dispose();
wrote in message news:5498985@discussion.autodesk.com...
Using system.io;
Announcements
Need installation help?
