.NET
Creating .dwg file Programmatically
31 REPLIES 31
Message 1 of 32
974 Views, 31 Replies
Hi All,
How to create a .dwg file with some entity example line, programmatically with c#, can any one help me with example please, thank's
Prakash
31 REPLIES 31
Message 2 of 32
using System.io
File.create("C:\\temp\\ex.dwg");
Message 3 of 32
Ed.Jobe
Can you open that example in acad?
Ed
How to post your code.
Message 4 of 32
Yes.Sure
Message 5 of 32
No, I tested it.
Creating dwg file is good,but can't open.
That's no available.
create .dvb file,.txt file ..... all is working, but can't open.
Message 6 of 32
Right Click - >Select that File name - >open
It's working in the txt files and other extension files.
but I test it the dwg file.it's true.i will try get a solution for that.
Message 7 of 32
Imports Autodesk.AutoCAD.Runtime
Imports System.io
Public Class GILSclass1
_
Public Sub EraseObjectsFromLayer()
File.Create("C:\\temp\\MyTest.dwg")
End Sub
End Class
Attempting to open created 'MyTest.dwg' file in the specified path, I meet the message of 'Drawing file is not valid.'
Message 8 of 32
Why would you think that the System.IO knows how to create a dwg file??
wrote in message news:5498917@discussion.autodesk.com...
Imports System.io
_
End Sub
End Class
Message 9 of 32
It's not my thougt, I only follow as you mentioned above.
Using system.io;
Message 10 of 32
I didn't mention anyting above...
Database db = new Database();
db.SaveAs(...);
db.Dispose();
wrote in message news:5498985@discussion.autodesk.com...
Using system.io;
Message 11 of 32
Yes, you're right.
I already knew from previous post in this site.
I just wish to know the above method shown by deepa is valid or not.
Imports Autodesk.AutoCAD.DatabaseServices
_
Public Sub CreateDrawingFile()
Dim db As Database = New Database(True, True)
db.SaveAs("C:\temp\MySecond.dwg", DwgVersion.Newest)
db.Dispose()
End Sub
End Class
Message 12 of 32
I got ya... But you tried it...~)
If you want to work on that doc now in the current document context - open
it and lock it.
Also pass "CommandSession.Flags" to your CommandMethod
[CommandMethod("SMD", CommandSession.Flags)]
Document newDoc = Application.DocumentManager.Open(dwgpath, false);
newDoc.LockDocument();
//now it's your active database - add lines or such as questioned by the OP.
wrote in message news:5499219@discussion.autodesk.com...
Yes, you're right.
_
db.Dispose()
End Sub
End Class
Message 13 of 32
Thank you,Palul.
What I can clear. ---> Adding commandFlags.Session,
newDoc is activated to the current drawing.
What I can get. --->I don't know what change was made with using method of newDoc.LockDocument.
Message 14 of 32
CommandFlags.Session -> makes the command available in the application
context
instead of just the calling doc.
newDoc.LockDocument ->Before you edit a doc you must lock it. When an app
runs
in the doc context the doc is locked for you. Others must be locked
manually.
Attached is a sample of a test. Keyword test!
wrote in message news:5499346@discussion.autodesk.com...
Thank you,Palul.
Message 15 of 32
>DocumentCollection docs
= Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager;
This is not used in the attached file - I should have deleted it.
"Paul Richardson" wrote in message
news:5499364@discussion.autodesk.com...
context
runs
manually.
Thank you,Palul.
Message 16 of 32
Paul, can you upload a similar example
for VS .NET 2003 / Acad2005 on VB.NET
Your prior example does not worked for me
Problem is on, I have not found on Browser
EditorInput in my VS version
Thanks in advance,
Fatty
~'J'~
Message 17 of 32
I don't have 05 installed. If you must use it to learn try getting the
ARX api - although I would avoid it as it was the first incarnation
of the api and not very complete. Not much help/samples available.
How about downloading the Acad07 trial and an Express version
of the .net compilers. Many samples with the ARX api and some
labs available from Autodesk. Also I would start with running
commands in the document context and worry about the session
context once you get up and running.
wrote in message news:5499463@discussion.autodesk.com...
Thanks in advance,
Fatty
~'J'~
Message 18 of 32
The result of LockDocument() must be
Disposed() of explicitly, because that is
what unlocks the document.
If you let the runtime do it (e.g., whenever
it gets around to it), the document remains
locked until that happens.
So,
using( DocumentLock myLock = newDoc.LockDocument() )
// work with locked document here
} // document is unlocked here
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"Paul Richardson" wrote in message news:5499364@discussion.autodesk.com...
context
runs
manually.
Thank you,Palul.
Message 19 of 32
Sweet! Thanks Tony. I couldn't find an unlock method so
assumed it was just magic..~)
"Tony Tanzillo" wrote in message
news:5499486@discussion.autodesk.com...
So,
context
runs
manually.
Thank you,Palul.
Message 20 of 32
Thanks for the quick reply
I agree I need to install a newer
VS version on my machine
I saw Acad07 Training VB.NET
and main problem is on many stuffs
frome there are not available for me
Fatty
~'J'~
”Boost
