.NET
Distinguished Contributor
Message 1 of 4 (272 Views)
Accepted Solution
Creating blocks, but not inserting correctly
272 Views, 3 Replies
03-22-2013 03:34 PM
I use the following code to create blocks in AutoCAD 2013.  When the user goes to insert this block, the insert command does not show a preview of the block when moving the mouse to locate it, and it comes in exploded.  This was working at one point, but something changed.  Is there some setting in AutoCAD or through the API that would cause this behavior?  Any other ideas?
Thanks!!
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Point3d p1 = new Point3d(0, 0, 0);
            Point3d p2 = new Point3d(10, 0, 0);
            Point3d p3 = new Point3d(10, 10, 0);
            using (Transaction Tx = db.TransactionManager.StartTransaction())
                BlockTable blkTbl = Tx.GetObject(db.BlockTableId, OpenMode.ForRead, false, true) as BlockTable;
                if (blkTbl.Has("TEST"))
                    // ...Warn the user
                else
                    BlockTableRecord btr = new BlockTableRecord();
                    btr.Name = "TEST";
                    blkTbl.UpgradeOpen();
                    ObjectId btrId = blkTbl.Add(btr);
                    Tx.AddNewlyCreatedDBObject(btr, true);
                    // Add entities
                    Line l1 = new Line(p1, p2);
                    l1.ColorIndex = 5;
                    btr.AppendEntity(l1);
                    Tx.AddNewlyCreatedDBObject(l1, true);
                    Line l2 = new Line(p2, p3);
                    l2.ColorIndex = 5;
                    btr.AppendEntity(l2);
                    Tx.AddNewlyCreatedDBObject(l2, true);
                    Tx.Commit();
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (256 Views)
Re: Creating blocks, but not inserting correctly
03-22-2013 04:23 PM in reply to: tommam
>> [...] and it comes in exploded
this code shows how you create a blockdefinition, it does not show how the user is inserting anything with preview or exploded.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
Message 3 of 4 (245 Views)
03-22-2013 07:50 PM in reply to: tommam
Blocks created by your plugin/extension do not get a preview icon automatically. You would need to use the BLOCKICON command or some other means of generating the preview icon.
As far as being inserted exploded, that's most-likely because the checkbox on the insert dialog is checked.
Message 4 of 4 (224 Views)
03-23-2013 07:51 AM in reply to: DiningPhilosopher
Yes, somehow the "Explode" checkbox got checked.  That took care of the preview also.  Now, when the user inserts, they see the preview and the block does not explode.  Don't I feel foolish!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
