.NET
Creating block + attributs + dynamic visibility DbObjectCollection
2 REPLIES 2
AubelecBE
313 Views, 2 Replies
I want to create à blockReference from a BlockTableRecord. (This contains attribut and Dynamic State).
I want to create this with in DbObjectCollection.
example with à DbText ;
Dim CollObject As New DBObjectCollection
Dim txt As DBText
  Txt = New DBText
  Txt.Position = New Point3d(PosX, PosY, PosZ)
  Txt.TextString = Texte
  Txt.Layer = "0"
 CollObject.Add(txt)
For Each ent As Entity In CollObject
                        BlocDef.AppendEntity(ent)
                        tr.AddNewlyCreatedDBObject(ent, True)
Next
It is possible to do the same with block + attribut + Dyn ?
or i need to insert the blockref for extract de Dynamic property ?
2 REPLIES 2
I'm not sure what you mean...but would guess that instead DBText you may want to use AttributeDefinition (for the BlockTableRecord) and a respective AttributeReference (for the BlockReference).
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
yes. i want to populate the DbObjectCollection with the blockRef + Attribute + Dynamic Visibility set to a good name.
”Boost
