I thought this would be easy at first, but keep getting an error:
"FileNotFoundException was unhandled" "Could not load file or assembly 'acdbmgd, Version=17.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
I thought I could read the drawing database externally using the ReadDwgFile method. If I use this in a Class Library (aka netloadable dll), it works fine, if used in an exe it doesn't.
Is it not possible to create a stand-alone .NET executable instead of a netloaded dll that can read various drawing databases outside of AutoCAD?
You cannot use the AutoCAD managed API from another process,
it's only usable from a NETLOADed DLL.
