Hi All,
I am creating a tool that can edit drawing title blocks, and also create new drawings, insert title block and edit the attributes.
Now, for existing drawings, this code is great and works well and can open the drawing after completion
{code}
Dim myDrawing As KBRDrawing = New KBRDrawing(LvwDrawings.Items(i).Tag)
myDrawing.OpenDrawingAsDatabase()
myDrawing.UpdateAttributes(LvwDrawings.Items(i), myStuff)
myDrawing.SaveDrawing()
myDrawing.CloseDrawing()
{code}
When I try to create the drawings, I can not open them and need to recover.
{code}
Dim myDrawing As New KBRDrawing(myItem.Tag)
myDrawing.CreateDrawing(myDrawing.FileName)
{code}
Here are the methods
{code}
Public Sub CreateDrawing(ByVal Filename As String)
Dim StrTemplate As String = "O:\G&I\CAD\Software\Acad\Perth\Clients\Wcorp\WCX_Acad\Sht\WC Template.dwt"
My.Computer.FileSystem.CopyFile(StrTemplate, Filename)
End Sub
Public Sub OpenDrawingAsDatabase()
Me.Database = New DatabaseServices.Database()
Try
' create a file stream from the file, opening it for read only exclusive rights
Dim FS As IO.FileStream = IO.File.Open(Me.FileName, IO.FileMode.Open, IO.FileAccess.Read, IO.FileShare.None)
' close and clean up right awat, if the open succeeded, we have our answer
FS.Close()
FS.Dispose()
FS = Nothing
Me.Database.ReadDwgFile(Me.FileName, DatabaseServices.FileOpenMode.OpenForReadAndAllShare, False, Nothing)
Catch ex As IO.IOException
Catch ex As Exception
MessageBox.Show("Unknown error occured" & Environment.NewLine & ex.Message)
End Try
End Sub
Public Sub SaveDrawing()
Try
Me.Database.SaveAs(Me.FileName, DatabaseServices.DwgVersion.Current)
MsgBox(ex.Message)
End Try
End Sub
Public Sub CloseDrawing()
Me.Database.Dispose()
End Sub
{code}
After I recover the drawing and open it, everything is completed correctly. I have narrowed it down to either the CreateDrawing being the offender, as this is the only difference in the 2 options above.
I have tried the CreateDrawing where it copies an existing dwg file, and it works fine, but when I use a dwt file, I need to recover.
Is there something that I have missed?
Edited by: BrentBurgess1980 on Apr 29, 2010 2:26 PM
