.NET
Valued Contributor
RamanSBV
Message 1 of 6 (341 Views)
Creating DWG using .Net
341 Views, 5 Replies
03-04-2012 08:36 PM
How i can create DWG using .Net.
While creating DWG file, i have to choose one of the dwg template and
location for created DWG file.
Raman
Alfred.NESWADBA
Message 2 of 6 (334 Views)
Re: Creating DWG using .Net
03-04-2012 11:09 PM in reply to: RamanSBV
do you want to have it opened in AutoCAD or do you just want to create a new file and open it just in memory?
Both samples:
      'first lines in the class have to include:
      'Imports Autodesk.AutoCAD
      Dim tTemplateFileName As String = "C:\TEMP\myTemplate.DWT"
      Dim tNewFileName As String = "C:\TEMP\newFile.DWG"
      'open it in editor
      Dim tNewDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.Add(tTemplateFileName)
      tNewDoc.CloseAndSave(tNewFileName)
      'open it as database in memory
      Dim tDb As DatabaseServices.Database = New DatabaseServices.Database(False, True)
      tDb.SaveAs(tNewFileName, DatabaseServices.DwgVersion.Current)
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 3 of 6 (316 Views)
03-05-2012 01:51 AM in reply to: Alfred.NESWADBA
Just I have to create a DWG with given template and and open it in AUTOCAD.
So, I have written below statements
 'open it in editor
      Dim tNewDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.Ad​d(tTemplateFileName)
But " tNewDoc.CloseAndSave(tNewFileName)" is not working ... means it is not creating file in given path
Then i changed to
  tNewDoc.Database.SaveAs(tNewFileName, trueDwgVersion.Current,                          tNewDoc.Database.SecurityParameters);
and it is creating file in given location.
Thanks for helping me.....
Alfred.NESWADBA
Message 4 of 6 (289 Views)
03-05-2012 09:35 AM in reply to: RamanSBV
Have you started that by a self-defined command? If so have you added the "Session"-flag?
- alfred -
Alfred NESWADBA
Valued Contributor
RamanSBV
Message 5 of 6 (265 Views)
03-05-2012 08:36 PM in reply to: RamanSBV
Sorry..I am not understanding what you are saying....can you please elaborate it.
-Raman
Alfred.NESWADBA
Message 6 of 6 (220 Views)
03-07-2012 05:50 AM in reply to: RamanSBV
you can define your own commands in your DLL, these commands do work either in document-context or in application-context. If they are working in document-context you can't activate an other document then that and that may be a problem if you try to open and/or to save another document then that where you started the command.
So take care of the attribtutes for your command-definition, one sample including the .Session flag:
<Autodesk.AutoCAD.Runtime.CommandMethod("OOCLoad", Autodesk.AutoCAD.Runtime.CommandFlags.Redraw Or Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet Or Autodesk.AutoCAD.Runtime.CommandFlags.Session)> _
Public Shared Sub OOCLoad()
End Sub
HTH, - alfred -
Alfred NESWADBA
You are not logged in.
Ask the Community
