.NET
Creating A Table With Preset Column Widths
1 REPLY 1
mgorecki
581 Views, 1 Reply
Hello, I have been able to create a table, populate the Title and Headers with text.  Which is all I want it to do for now.  The problem is, I can calculate how wide I want each column, but it never gets drawn with the correct column width.
Anyone know how to make it use the correct column width specified?  Keep in mind all of the column widths may differ.
Attached is my code.
Public Sub AddTable(ByVal dwg_scale As Double, ByVal dwgTextHeight As Double)
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Using tableTrans As Transaction = db.TransactionManager.StartTransaction()
            Dim txtTbl As TextStyleTable = tableTrans.GetObject(db.TextStyleTableId, OpenMode.ForRead)
            Dim smdTable As New Table()
            smdTable.TableStyle = db.Tablestyle
            Dim tblStyle As TableStyle = tableTrans.GetObject(smdTable.TableStyle, OpenMode.ForWrite)
            Dim hdrCellHgt As Double, dtaCellHgt As Double, smdCol0Width As Double, smdCol1Width As Double
            Dim smdCol2Width As Double, smdCol3Width As Double, smdCol4Width As Double
            Dim tableLocX As Double, tableLocY As Double, tableLoc As Point3d
            hdrCellHgt = ((dwgTextHeight * 2) + (dwgTextHeight * 1.5)) 'this is setting the header row height
            dtaCellHgt = (dwgTextHeight * 2) 'this is setting the title and data row heights
            smdCol0Width = 13.0 * dwg_scale
            smdCol1Width = 14.8 * dwg_scale
            smdCol2Width = 14.8 * dwg_scale
            smdCol3Width = 19.6 * dwg_scale
            smdCol4Width = 25.4 * dwg_scale
            tableLocX = (((smdCol0Width + smdCol1Width + smdCol2Width + smdCol3Width + smdCol4Width) / 2.0) * -1)
            tableLocY = ((dtaCellHgt * 2) + hdrCellHgt)
            tableLoc = New Point3d(tableLocX, tableLocY, 0)
            tblStyle.SetTextStyle(txtTbl("Romans"), RowType.TitleRow)
            tblStyle.SetTextStyle(txtTbl("Romans"), RowType.HeaderRow)
            tblStyle.SetTextStyle(txtTbl("Romans"), RowType.DataRow)
            smdTable.Position = tableLoc
            smdTable.InsertRows(0, dtaCellHgt, 1)
            smdTable.Rows(0).Style = "Title"
            smdTable.Cells(0, 0).TextString = "DISCRETE COMPONENTS"
            smdTable.InsertRows(1, hdrCellHgt, 1)
            smdTable.InsertRows(2, dtaCellHgt, 1)
            smdTable.InsertColumns(0, smdCol0Width, 1)
            smdTable.InsertColumns(1, smdCol1Width, 1)
            smdTable.InsertColumns(2, smdCol2Width, 1)
            smdTable.InsertColumns(3, smdCol3Width, 1)
            smdTable.InsertColumns(4, smdCol4Width, 1)
            smdTable.DeleteColumns(5, 1)
            smdTable.DeleteRows(3, 1)
            smdTable.Rows(1).Style = "Header"
            smdTable.Rows(1).TextHeight = dwgTextHeight
            smdTable.Rows(2).Style = "Data"
            smdTable.Rows(2).TextHeight = dwgTextHeight
            smdTable.Rows(1).Alignment = CellAlignment.MiddleCenter
            smdTable.Rows(2).Alignment = CellAlignment.MiddleCenter
            smdTable.Cells.Alignment = CellAlignment.MiddleCenter
            smdTable.Cells.TextHeight = dwgTextHeight
            smdTable.Cells(1, 0).TextString = "ITEM NO."
            smdTable.Cells(1, 1).TextString = "X"
            smdTable.Cells(1, 2).TextString = "Y"
            smdTable.Cells(1, 3).TextString = "Z (HEIGHT)"
            smdTable.Cells(1, 4).TextString = "COMPONENT TYPE"
            Dim bt As BlockTable = tableTrans.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim smdTableBtr As BlockTableRecord = tableTrans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            smdTable.GenerateLayout()
            smdTableBtr.AppendEntity(smdTable)
            tableTrans.AddNewlyCreatedDBObject(smdTable, True)
            tableTrans.Commit()
        End Using
    End Sub
1 REPLY 1
Hallex
in reply to: mgorecki
Try example from this page
http://www.acadnetwork.com/topic-199.0.html
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
”Boost
