.NET
Create pc3 File from acad
3 REPLIES 3
673 Views, 3 Replies
Does anyone know how to use the PlottingServices.PlotConfig.SaveToPc3() Method?
Been trying all day and have not had any result.
Try
For Each P As Autodesk.AutoCAD.PlottingServices.PlotConfigInfo In Autodesk.AutoCAD.PlottingServices.PlotConfigManager.Devices
Try
Dim oEditor As Autodesk.AutoCAD.EditorInput.Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
If P.DeviceName.EndsWith(".pc3") = False Then
If Not P.DeviceName = "None" Then
'oEditor.WriteMessage("Now Updating Pagesetups for all layouts referencing " + P.DeviceName + vbNewLine)
Autodesk.AutoCAD.PlottingServices.PlotConfigManager.SetCurrentConfig(P.DeviceName.ToString)
Dim oPlotConfig As Autodesk.AutoCAD.PlottingServices.PlotConfig = Autodesk.AutoCAD.PlottingServices.PlotConfigManager.CurrentConfig
'Application.ShowAlertDialog(Autodesk.AutoCAD.PlottingServices.PlotConfigManager.Devices)
'Application.ShowAlertDialog(oPlotConfig.CanonicalMediaNames(0))
Dim Fullnamepc3 As String() = oPlotConfig.DeviceName.Split("\")
Dim pc3name As String
If Fullnamepc3.Length > 0 Then
pc3name = Fullnamepc3(Fullnamepc3.GetUpperBound(0)) + ".pc3"
oPlotConfig.SaveToPC3(pc3name)
Application.ShowAlertDialog(pc3name)
oPlotConfig = Nothing
oEditor = Nothing
Catch ex As Exception
Application.ShowAlertDialog("Please contact IT Department and request " + P.DeviceName + " printer driver installation.")
End Try
Next
Application.ShowAlertDialog(ex.Data)
Finally
End Try
3 REPLIES 3
when you debug, how far does it get?
Does the p3c anme get constructed correctly?
Human.Man.Name=Jose <>
|>Try
|> Try
|> End If
|> oEditor = Nothing
|> End If
|> End If
|> End If
|> End Try
|> Next
|> Finally
|> End Try
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
I constructed the name of the file just fine. I spent some time looking at the object arx sdk and discovered that the method takes the entire qualified path and filename. I was only giving it a name. After I included the path it all works just fine.
slick, thanks for the code then 🙂
James Maeding
”Boost
