• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Create instance of my object
    251 Views, 9 Replies
    05-01-2012 04:38 PM
    I have created a class that inherits Polyline. I have added properties to that class.
    When I try to SetDatabaseDefaults with my object, I get an error "Set database defaults is not a member..."
    But if I create a new Polyline, SetDatabaseDefaults works for that object.
    Shouldn't the SetDatabaseDefaults method become a member of my class when I inherit from Polyline?
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: Create instance of my object
    05-01-2012 09:50 PM in reply to: tcorey
    tcorey wrote:
    I have created a class that inherits Polyline...
    Is it a .NET class?
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    05-02-2012 08:22 AM in reply to: Alexander.Rivilis
    Yes, this is a .Net class.
    Tim Corey, Owner
    Redding, CA
    05-02-2012 08:30 AM in reply to: tcorey
    I figured it out.
    I had originally inherited from Autodesk.AutoCAD.GraphicsInterface.Polyline, but if I inherit from Autodesk.AutoCAD.DatabaseServices.Polyline instead, the object will setdatabasedefaults.
    I don't know why one polyline would have different properties than another, but I'm not gonna let myself get hung up on that detail right now!
    So, advice for other newbies, there might be multiple Autodesk-supplied classes in various Autodesk libraries. Those classes might use the same name but not have the same properties and methods.
    Thanks, Alexander, for responding. I'm sure you'll be seeing more beginner-level posts from me....
    Tim Corey, Owner
    Redding, CA
    Moderator
    Alexander.Rivilis
    05-02-2012 02:56 PM in reply to: tcorey
    As I understand you try to create custom entity with help of .NET API. Am I right? It is impossible to create custom entity with help of .NET API. It is possible only with help of ObjectARX (C++). Therefore no sense to create classes inherited from DBObject / Entity, as an instance of this class will not be able to create and add to the dwg-file.
    05-04-2012 01:24 AM in reply to: Alexander.Rivilis
    Wow. Thanks, Alexander. You just saved me a bunch of hours.
    The reason I was going to create my own class was so I could apply properties to a polyline-like object, like you would with Xdata through Visual LISP. Is there a way to apply custom properties to an AutoCAD object using VB.NET, without creating my own class?
    Or should I just switch to C++?
    Tim Corey, Owner
    Redding, CA
    Moderator
    Alexander.Rivilis
    05-04-2012 01:46 AM in reply to: tcorey
    What do you mean by Custom Property? What do you mean by Custom Property? The property which appears in the Properties pane (OPM)?
    Try code of Kean Walmsley: http://through-the-interface.typepad.com/through_the_interface/2009/05/modifying-an-autocad-objects-...
    Only if you ready to create own custom entity. This is not the easy way. Good luck!
    05-04-2012 02:22 PM in reply to: tcorey
    By Custom Properties, I mean my own properties and values assigned to a polyline object. In particular, I want to create a property that holds the View to which my polyline is associated. Using Visual LISP, I would create Xdata to do this.
    I read through Kean's post and it appears that there is a way to do this with vb.net, so I might continue down that road for now. Or not. Maybe I'll switch to c++, although it's been even longer since I used it than it has been for VB.
    Decisions, decisions....
    Tim Corey, Owner
    Redding, CA
    05-05-2012 05:13 AM in reply to: tcorey
    Using .NET, you also can create Xdata or ExtensionDictionary/Xrecord,this would certainly be simpler than the objectARX/C++ route...
    Gilles Chanteau
    05-08-2012 10:52 AM in reply to: tcorey
    Thanks!
    Tim Corey, Owner
    Redding, CA
