Create an extruded Solid3d from a polyline
I'm trying to create a Solid3d that is the extrusion solid af a closed polyline by a given height
I select the polyline that i do this
Solid3d s = new Solid3d();
s.CreateExtrudedSolid(selectedPolyline, new Vector3d(0, 0, 20), new SweepOptions());
but Autocad throw an eInvalidInput exception.
What is wrong in this code?
Hallex
Give this a shot
{code}
       <CommandMethod("mysolid")> _
        Public Sub CreateExtruded()
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = acDoc.Editor
            Dim db As Database = acDoc.Database
            Try
                Using tr As Transaction = db.TransactionManager.StartTransaction
                    Dim peo As New PromptEntityOptions(vbLf & "Select closed curve >>")
                    peo.SetRejectMessage(vbLf & "Selected is not a curve>>")
                    peo.AddAllowedClass(GetType(Curve), False)
                    Dim res As PromptEntityResult
                    res = ed.GetEntity(peo)
                    If res.Status <> PromptStatus.OK Then
                        Return
                    Dim ent As Entity = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), Entity)
                    If ent Is Nothing Then
                        Return
                    Dim curv As Curve = DirectCast(ent, Curve)
                    Dim coll As DBObjectCollection = New DBObjectCollection()
                    coll.Add(curv)
                    Dim dbcoll As DBObjectCollection = New DBObjectCollection()
                    dbcoll = Region.CreateFromCurves(coll)
                    Dim reg As Region = dbcoll(0)
                    Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) '<-- get current space
                    btr.AppendEntity(reg)
                    tr.AddNewlyCreatedDBObject(reg, True)
                    peo = New PromptEntityOptions(vbLf & "Select extruded path >>")
                    peo.AddAllowedClass(GetType(Polyline3d), False)
                    peo.AddAllowedClass(GetType(Line), False)
                   '' ----------------   add other types here    --------------- ''
                        Return
                    ent = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForRead), Entity)
                        Return
                    Dim expath As Curve = Nothing
                    Dim ln As Line = Nothing
                    Dim pline As Polyline3d = Nothing
                    If TypeOf ent Is Line Then
                        expath = DirectCast(ent, Curve)
                    ElseIf TypeOf ent Is Polyline3d Then
                    Dim sold As Solid3d = New Solid3d()
                    sold.RecordHistory = True
                    sold.ExtrudeAlongPath(reg, expath, 0.0)
                    btr.AppendEntity(sold)
                    tr.AddNewlyCreatedDBObject(sold, True)
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(String.Format( _
                                   "ERROR: " & Environment.NewLine & "{0}" & Environment.NewLine _
                                   & "TRACE: " + Environment.NewLine + "{1}", ex.Message, ex.StackTrace))
            Finally
                'do nothing
            End Try
        End Sub
{code}
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Hallex
In addition, by my limited test the following code is working too
{code}
Dim sold AsSolid3d = NewSolid3d()
' sold.ExtrudeAlongPath(reg, expath, 0.0)'<-- works in 2009 / 2010
' sold.CreateExtrudedSolid(curv, New Vector3d(0, 0, 20), New SweepOptions()) ' <-- works in 2010
sold.CreateExtrudedSolid(curv,NewVector3d(1, 2, 20), NewSweepOptions()) ' <-- works in 2010
True)
tr.Commit()
{code}
coll.Add(curv)
The above code don't work (throw eInvalidInput) if the curve (curv) is a Polyline3D!
Why?
Hallex
As I remember from Help file the allowed types
for creating region does not contains 3Dpoly
See your self, mybe I'm wrong
~'J'~
