.NET
matinau
Message 1 of 4 (299 Views)
Create a workspace from an existing workspace .NET
299 Views, 3 Replies
03-05-2013 11:22 PM
Hi I'm trying to create / copy an existing workspace using c#
I couldn't find a direct way to just copy the existing workspace so I tried to add it's properties manually. The only trouble is I can't seem to cover all the settings here's what I have so far... any help would be much appreciated.
var userworkspace = new Workspace(cs, acadUser)
  WorkspaceRibbonRoot = wsMaster.WorkspaceRibbonRoot,
  WorkspaceQuickAccessToolbar = wsMaster.WorkspaceQuickAccessToolbar,
  Name = acadUser
foreach (WorkspaceToolbar wst in wsMaster.WorkspaceToolbars)
 userworkspace.WorkspaceToolbars.Add(wst);
foreach (WorkspacePopMenu wsp in wsMaster.WorkspacePopMenus)
 userworkspace.WorkspacePopMenus.Add(wsp);
Pretty basic I know, how can I get PartialCUI tabs, palettes, etc.. applied?
Cheers
matinau
Message 2 of 4 (268 Views)
Re: Create a workspace from an existing workspace .NET
03-06-2013 09:29 PM in reply to: matinau
Ok so I figured out how to create my new workspace from an existing workspace... pretty much what I had previously. The only trouble now is that the newly created workspace isn't full recognised i.e. I can't set it current unless I do it through the cui editor or restart CAD?
How do I properly update?
Thanks in advance, Matt
Moderator
Alexander.Rivilis
Message 3 of 4 (264 Views)
03-06-2013 10:36 PM in reply to: matinau
It is look like you have to unload/load cui(x)-file with help of Application.UnloadPartialMenu/Application.LoadPartialMenu and set WORKSPACE system variable with help of Application.SetSystemVariable
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
matinau
Message 4 of 4 (251 Views)
03-07-2013 02:07 PM in reply to: Alexander.Rivilis
Thanks for the reply, unfortunately I needed to reload the main cui file not a partial cui. The following actually worked?
Application.LoadMainMenu(csMain.CUIFileName);
since there was no "UnloadMainMenu" I called the above code whilst the main cui was loaded which seemed to work? The only annoyance been the number of times the environment reloaded.
1st - on initial load
2nd - on "LoadMainMenu"
3rd - on "SetcurrentWorkspace"
Can you think of a better / alternative way other than sendstringcommand? Will this approach cause problems since the main cui was never unloaded.
If not I'll run with this, thanks
You are not logged in.
Ask the Community
