• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Create a workspace from an existing workspace .NET
    131 Views, 3 Replies
    03-05-2013 11:22 PM
    Hi I'm trying to create / copy an existing workspace using c#
    I couldn't find a direct way to just copy the existing workspace so I tried to add it's properties manually. The only trouble is I can't seem to cover all the settings here's what I have so far... any help would be much appreciated.
    var userworkspace = new Workspace(cs, acadUser)
      WorkspaceRibbonRoot = wsMaster.WorkspaceRibbonRoot,
      WorkspaceQuickAccessToolbar = wsMaster.WorkspaceQuickAccessToolbar,
      Name = acadUser
    foreach (WorkspaceToolbar wst in wsMaster.WorkspaceToolbars)
     userworkspace.WorkspaceToolbars.Add(wst);
    foreach (WorkspacePopMenu wsp in wsMaster.WorkspacePopMenus)
     userworkspace.WorkspacePopMenus.Add(wsp);
    Pretty basic I know, how can I get PartialCUI tabs, palettes, etc.. applied?
    Cheers
    Please use plain text.
    Re: Create a workspace from an existing workspace .NET
    03-06-2013 09:29 PM in reply to: matinau
    Ok so I figured out how to create my new workspace from an existing workspace... pretty much what I had previously. The only trouble now is that the newly created workspace isn't full recognised i.e. I can't set it current unless I do it through the cui editor or restart CAD?
    How do I properly update?
    Thanks in advance, Matt
    Moderator
    Alexander.Rivilis
    03-06-2013 10:36 PM in reply to: matinau
    It is look like you have to unload/load cui(x)-file with help of Application.UnloadPartialMenu/Application.LoadPartialMenu and set WORKSPACE system variable with help of Application.SetSystemVariable
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    03-07-2013 02:07 PM in reply to: Alexander.Rivilis
    Thanks for the reply, unfortunately I needed to reload the main cui file not a partial cui. The following actually worked?
    Application.LoadMainMenu(csMain.CUIFileName);
    since there was no "UnloadMainMenu" I called the above code whilst the main cui was loaded which seemed to work? The only annoyance been the number of times the environment reloaded.
    1st - on initial load
    2nd - on "LoadMainMenu"
    3rd - on "SetcurrentWorkspace"
    Can you think of a better / alternative way other than sendstringcommand? Will this approach cause problems since the main cui was never unloaded.
    If not I'll run with this, thanks
