.NET
matinau
Message 1 of 6 (621 Views)
Accepted Solution
Create Named View - ViewTwist Problems??
621 Views, 5 Replies
08-09-2012 03:31 PM
Hi, I'm trying to create a function that creates a ucs, defines a named view and algins to the current view based on a blockreference (in this case it will be the last selected entity). So far everythings working except I can't get the view to rotate or "twist" properly? Can you have a look to see where I'm going wrong. Here's the full code, the polyline that's created should frame the view.
[CommandMethod("VM")]
        public static void NamedView()
            // Test Values for Named View
            string viewname = "100 m";
            double width = 420;
            double height = 297;
            double angle = 0;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                BlockTableRecord ms = (BlockTableRecord)tr.GetObject(
                    bt[BlockTableRecord.ModelSpace],
                    OpenMode.ForWrite);
                // Catch last entity (MVF Block) and align UCS
                ObjectId ent = Autodesk.AutoCAD.Internal.Utils.EntLast();
                if (ent.ObjectClass.DxfName == "INSERT")
                    BlockReference blk = (BlockReference)tr.GetObject(ent, OpenMode.ForRead);
                    ed.CurrentUserCoordinateSystem = blk.BlockTransform;
                    angle = blk.Rotation;
                else
                    ed.WriteMessage("Last entity was not a block reference");
                    return;
                // Get Current coordinate system
                CoordinateSystem3d cs = ed.CurrentUserCoordinateSystem.CoordinateSystem3d;
                Point3d ucsOrigin = cs.Origin; // Used later for View Origin creation
                // Create New User UCS
                UcsTable ut = (UcsTable)tr.GetObject(db.UcsTableId, OpenMode.ForRead);
                UcsTableRecord utr;
                if (ut.Has(viewname))
                    utr = (UcsTableRecord)tr.GetObject(
                        ut[viewname], OpenMode.ForWrite);
                else
                    utr = new UcsTableRecord();
                    utr.Name = viewname;
                    ut.UpgradeOpen();
                    ut.Add(utr);
                    tr.AddNewlyCreatedDBObject(utr, true);
                utr.Origin = ucsOrigin;
                utr.XAxis = cs.Xaxis;
                utr.YAxis = cs.Yaxis;
                ViewportTableRecord vptr = tr.GetObject(doc.Editor.ActiveViewportId,
                    OpenMode.ForWrite) as ViewportTableRecord;
                vptr.IconAtOrigin = true;
                vptr.IconEnabled = true;
                vptr.SetUcs(utr.ObjectId);
                doc.Editor.UpdateTiledViewportsFromDatabase();
                // Create View
                ViewTable vt = (ViewTable)tr.GetObject(db.ViewTableId, OpenMode.ForRead);
                ViewTableRecord vtr;
                // Check if View Name exit's
                if (vt.Has(viewname))
                    vtr = (ViewTableRecord)tr.GetObject(vt[viewname], OpenMode.ForWrite);
                else
                    vtr = new ViewTableRecord();
                    vtr.Name = viewname;
                    vt.UpgradeOpen();
                    ObjectId vtId = vt.Add(vtr);
                    tr.AddNewlyCreatedDBObject(vtr, true);
                // Calculate center point if view
                double centerX = width / 2;
                double centerY = height / 2;
                Point2d ctr = new Point2d(centerX, centerY);
                //Convert to ucs origin to Point2d
                Point2d viewOrigin = new Point2d(ucsOrigin.X, ucsOrigin.Y);
                //Create a rotation Matrix for X and Y Axis
                Matrix2d mat = Matrix2d.Rotation(angle, Point2d.Origin);
                Matrix2d mat2d = new Matrix2d();
                mat2d = Matrix2d.AlignCoordinateSystem(
                    Point2d.Origin,
                    Vector2d.XAxis,
                    Vector2d.YAxis,
                    viewOrigin,
                    new Vector2d(1, 0).TransformBy(mat),
                    new Vector2d(0, 1).TransformBy(mat)
                Point2d viewCenter = ctr.TransformBy(mat2d);
                vtr.ViewTwist = -angle;
                vtr.IsPaperspaceView = false;
                vtr.CenterPoint = viewCenter;
                vtr.SetUcs(utr.ObjectId);
                vtr.Height = height;
                vtr.Width = width;
                // Set new view to current
                ed.SetCurrentView(vtr);
                // Create Polyline test geometry
                // Defined bouding box to new View
                Point2d pt1 = new Point2d(0, 0);
                Point2d pt2 = new Point2d(width, 0);
                Point2d pt3 = new Point2d(width, height);
                Point2d pt4 = new Point2d(0, height);
                Point2d[] pts = { pt1, pt2, pt3, pt4 };
                // Define Polyline Vertices
                Polyline pl = new Polyline(4);
                int max = pts.GetUpperBound(0);
                for (int i = 0; i <= max; i++)
                    int j = (i == max ? 0 : i + 1);
                    pl.AddVertexAt(i, pts.TransformBy(mat2d), 0, 0, 0);
                pl.Closed = true;
                // Add the boundary to modelspace
                ObjectId id = ms.AppendEntity(pl);
                tr.AddNewlyCreatedDBObject(pl, true);
                tr.Commit();
matinau
Message 2 of 6 (577 Views)
Re: Create Named View - ViewTwist Problems??
08-15-2012 04:48 PM in reply to: matinau
Can anyone help, still no closer to fixing this problem. Cheers
*Expert Elite*
Jeff_M
Message 3 of 6 (565 Views)
08-15-2012 08:31 PM in reply to: matinau
Well, I'm guessing there was an error introduced by the copy/paste operation, as this needed correcting:
to this:
pl.AddVertexAt(i, pts[j].TransformBy(mat2d), 0, 0, 0);
But once that was done, it appears to work fine as far as the rotation goes. It's not centering the view on the polyline or the blockreference, but I'm not sure if it's supposed to be.
In this image, the dashed line is the edge of the drawing canvas when the created view is is current. But, the UCS and code generated polyline appear to match the rotation of the water valve block which was inserted with a rotation of 33 degrees.
Hope that helps you track down what you are looking for.
Jeff_M, also a frequent Swamper
matinau
Message 4 of 6 (563 Views)
08-15-2012 08:49 PM in reply to: Jeff_M
Hi thanks for the reply not sure how that happened? however part I need help with is how to center the view within the polyline. this is what happens when I edit the boundaries of the named view create "100 m"
viewstuff
the Yellow line is the block, the white is the polyline created on the VM command and the black rectangle is the boundaries of "100 m" view?
I want this to be centered within the polyline?
If I remove the vtr.viewtwist line the view is centered wwithin the polyline but the rotations out....if I uncomment this line I get the above result.
Any ideas?
ADN Support Specialist
Balaji_Ram
Message 5 of 6 (524 Views)
08-22-2012 01:51 PM in reply to: matinau
The CenterPoint of the ViewtableRecord is to be provided in DCS. In the below sample code, I set the view width and height for the current view. I then perform the transformation of the center point from UCS to DCS and set it as the centerpoint of the viewtable record.
    double width = 420;
    double angle = 0;
            OpenMode.ForWrite);
        else
            return;
        UcsTableRecord utr;
        else
            ut.UpgradeOpen();
            ut.Add(utr);
        // Create View
        // Check if View Name exists
            vtr = tr.GetObject(vt[viewname], OpenMode.ForWrite) as ViewTableRecord;
        else
            vt.UpgradeOpen();
            Point2d.Origin,
            Vector2d.XAxis,
            Vector2d.YAxis,
            viewOrigin,
        vtr.Width = width;
		//// Set the CenterPoint of the VTR in DCS
		ResultBuffer ucs = new ResultBuffer(new TypedValue(5003, 1));    // UCS
		ResultBuffer dcs = new ResultBuffer(new TypedValue(5003, 2));    // DCS
		Point3d viewCenter3d_ucs = new Point3d(ctr.X, ctr.Y, 0.0);
		double[] fromPt = viewCenter3d_ucs.ToArray();
		double[] toPt = new double[] { 0, 0, 0 };
		acedTrans(fromPt, ucs.UnmanagedObject, dcs.UnmanagedObject, 0, toPt);
		Point3d viewCenter3d_dcs = new Point3d(toPt[0], toPt[1], toPt[2]);
		vtr.CenterPoint = new Point2d(viewCenter3d_dcs.X, viewCenter3d_dcs.Y);
        pl.Closed = true;
        tr.Commit();
Balaji
Developer Technical Services
Autodesk Developer Network
matinau
Message 6 of 6 (383 Views)
03-08-2013 01:21 PM in reply to: Balaji_Ram
Same idea, slightly different approach for anyone interested
Matrix3d WCS2DCS =
Matrix3d
.PlaneToWorld(vtr.ViewDirection)
.PreMultiplyBy(Matrix3d.Displacement(vtr.Target - Point3d.Origin))
.PreMultiplyBy(Matrix3d.Rotation(-vtr.ViewTwist, vtr.ViewDirection, vtr.Target))
.Inverse();
Point3d viewCenter = blk.Position.TransformBy(WCS2DCS);
vtr.CenterPoint = new Point2d(viewCenter.X + width / 2.0, viewCenter.Y + height / 2.0);
You are not logged in.
Announcements
Need installation help?
Ask the Community
