Message 1 of 17
12:13 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Even after much searching and asking for help, I have not come to a solution for creating DBTEXT elements within a BackgroundWorker, this element has problem with the alignment point. So there is an example ZIP to anyone who can help, just run the command and check the elements created, you will see that I'm creating the element with the point in alinahmento MIDLECENTER but the result is not correct.
I am creating other elements in the same way and they had no problems (MTEXT, POLYLINE, CIRCLE, SPLINE, LINE, etc. ..), they are correct, but the element and the element DBTEXT block that contains attributes present problems in the alignment points.
