.NET
Member
Message 1 of 7 (398 Views)
Crash when Transaction takes too long
398 Views, 6 Replies
07-24-2012 11:36 PM
Hello everyone,
i have got a problem with AutoCAD 2010 right now. Im having some procedures that take very long to process in between a TransactionManager.StartTransaction and Commit/Abort.
When taking too long AutoCAD sometimes just disappears/crashes without giving a call stack/Exception or anything. There are also no memory leaks or exceptions raised, though i send some status messages to the command line of AutoCAD.
Does AutoCAD need anything like a KeepAlive? Do i have to send it some specific messages or anything? Is that a common problem?
Valued Mentor
Message 2 of 7 (378 Views)
Re: Crash when Transaction takes too long
07-25-2012 06:52 AM in reply to: OrgadataPST
Please show the code, and any other relevant information like platform, VS version, .NET Framework, drawing size (posting a sample dwg is very useful) , etc.
Gaston Nunez
Member
Message 3 of 7 (374 Views)
07-25-2012 07:19 AM in reply to: gasty1001
Sadly i can not provide the drawing, because it crashes where the drawing gets generated.
VS-Version: 2008 C# Standard
.NET: 3.5
And here is the C# code(modified though):
using (Transaction acTransaction = TransactionManager.StartTransaction())
                try
                    CurrentTransaction = acTransaction;
                    BlockTableRecord acBlockTableRecord = acTransaction.GetObject(BlockIds.Peek(),
                            OpenMode.ForWrite) as BlockTableRecord;
                    // Create a new object
                    Region acRegion = GetProfileRegion(profile);
                    Polyline3d acPath = GetExtrusionPath(profile.Axis);
                    Solid3d acSolid = new Solid3d();
                    acSolid.SetDatabaseDefaults();
                    acSolid.ExtrudeAlongPath(acRegion, acPath, 0);
                    Solid3d acSlicedSolid = acSolid;
                    try
                        SolidAnalyzer.GetFaceNormals(profile, acSolid);
                    finally
                        if (acSlicedSolid != null)
                            acSlicedSolid.Color = Autodesk.AutoCAD.Colors.Color.FromColor(profile.OuterColor);
                    // Append the newly created object to model space and active transaction
                    acBlockTableRecord.AppendEntity(acSlicedSolid);
                    acTransaction.AddNewlyCreatedDBObject(acSlicedSolid, true);
                    acRegion.Dispose();
                    acPath.Erase();
                    // Save changes to database and close transaction
                    acTransaction.Commit();
                    AutoCADApplication.Print("Profile: " + profile.Name + " successfully constructed.");
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    AutoCADApplication.Print("Failed to construct profile " + profile.Name
                        + "\n" + ex.Message + "\n\n" + ex.StackTrace);
                    acTransaction.Abort();
                finally
                    CurrentTransaction = null;
The GetProfileRegion and GetExtrusionPath Methods always work/never crashed before and i can´t post them for different reasons. The profile region is a highly detailed cut of a window profile.
The SolidAnalyzer class is defined as follows:
public static class SolidAnalyzer
        private static string Vector3dToString(Vector3d vector)
            return "[" +
                vector.X.ToString("F2") + ", " +
                vector.Y.ToString("F2") + ", " +
                vector.Z.ToString("F2")
        private static Vector3d GetFaceNormal(Autodesk.AutoCAD.BoundaryRepresentation.Face face, Point3d point)
            PointOnSurface ptOnSurf = face.Surface.GetClosestPointTo(point);
            Point2d param = ptOnSurf.Parameter;
            Vector3d normal = ptOnSurf.GetNormal(param);
            Vector3d normalTest = normal.MultiplyBy(1E-6 / normal.Length);
            Point3d ptTest = point.Add(normalTest);
            PointContainment ptContainment = new PointContainment();
            bool reverse = false;
            using(BrepEntity brepEnt = face.Brep.GetPointContainment(ptTest, out ptContainment))
                if(ptContainment != PointContainment.Outside)
                    reverse = true;
            return normal.MultiplyBy(reverse ? -1.0 : 1.0);
        public static List<Vector3d> GetFaceNormals(Profile profile, Solid3d profileSolid)
            List<Vector3d> faceNormals = new List<Vector3d>();
            using (Brep brep = new Brep(profileSolid))
                foreach (Autodesk.AutoCAD.BoundaryRepresentation.Face face in brep.Faces)
                    using (BrepEntity brepEnt = face.GetPointContainment(new Point3d(0, 0, 0), out ptContainment))
                        faceNormals.Add(GetFaceNormal(face, new Point3d(0, 0, 0)));
                        //if (ptContainment == PointContainment.Inside ||
                        //    ptContainment == PointContainment.OnBoundary)
                            AutoCADApplication.Print("\nFace Normal at " +
                                "[0, 0, 0] = " + Vector3dToString(GetFaceNormal(face, new Point3d(0, 0, 0))));
            return faceNormals;
After adding the SolidAnalyzer class and using GetFaceNormals AutoCAD sometimes first freezes/does not respond and then crashes or disappears after some normals have been written to the commandline.
 This procedure takes very long because the solid3d has >300 faces most of the time.
ADN Support Specialist
Message 4 of 7 (340 Views)
07-30-2012 04:14 PM in reply to: OrgadataPST
I have not run your code to test what's going on exactly, but i can guess just looking... Please see my comments below...
    try
        // Fenton : you must dispose all AutoCAD objects before
        // this function goes out of scope, use using. Otherwise those objects will be disposed by the GC on a worker thread, which will most likely crash AutoCAD
        using (Region acRegion = GetProfileRegion(profile))
          using (Polyline3d acPath = GetExtrusionPath(profile.Axis))
            using (Solid3d acSolid = new Solid3d())
              // Fenton: what does this line mean? if you are trying
              // to make a copy, think again because it won't
              //Solid3d acSlicedSolid = acSolid;
              // Fenton: this is better
              Solid3d acSlicedSolid = new Solid3d();
              acSlicedSolid.CopyFrom(acSolid);
              try
              finally
              acPath.Erase();
    finally
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Message 5 of 7 (339 Views)
07-30-2012 04:30 PM in reply to: fenton.webb
I also just posted this for you guys...
http://adndevblog.typepad.com/autocad/2012/07/forcing-the-gc-to-run-on-the-main-thread.html
Fenton Webb
Member
Message 6 of 7 (320 Views)
07-31-2012 12:12 AM in reply to: fenton.webb
Thanks, Fenton.
The line where it says acSlicedSolid= ... was just a remain of a slicing procedure i commented out to test, sadly i forgot that line. It wasn´t intended to copy anything, it´s not a struct. Was used to determine which Solid3d to be cut because it was cut multiple times and that one was just a pointer to it.
Anyways, the GC won´t collect them in this case cause the objects are still referenced and using "using" doesn´t solve it either. I´ve just splitted it into multiple small transactions now and somehow it works.
I can´t really tell why though..., thanks a lot for the help.
Message 7 of 7 (306 Views)
07-31-2012 09:05 AM in reply to: OrgadataPST
No problem.
If you post a working sample project, I'll take a look at it for you.
Fenton Webb
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
