• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Counting instances of an image
    104 Views, 4 Replies
    05-29-2012 01:45 AM
    Hi there,
    I can find which images are attached to my current drawing with the following code. However, I don't know how to find out how many times they are attached.
    Anybody ?
    Using tr As Transaction = db.TransactionManager.StartTransaction
    	Try
    		Dim nod As DBDictionary
    		Dim imageDict As DBDictionary
    		Console.WriteLine("Getting ACAD_IMAGE_DICT DB dictionary")
    		nod = CType(tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, False), DBDictionary)
    		imageDict = CType(tr.GetObject(nod.GetAt("ACAD_IMAGE_DICT"), OpenMode.ForRead, False), DBDictionary)
    		For Each dicentry As DBDictionaryEntry In imageDict
    			Dim myRasterImgDef As RasterImageDef = CType(tr.GetObject(CType(dicentry.Value, ObjectId), OpenMode.ForRead), RasterImageDef)
    			If myRasterImgDef.IsLoaded Then
    				Console.WriteLine("Found: " & myRasterImgDef.ActiveFileName)
    				' NEED TO COUNT INSTANCES HERE
    			Else
    				Console.WriteLine("Not found: " & myRasterImgDef.SourceFileName)
    			End If
    		Next
    		tr.Commit()
    	Catch ex As Exception
    		System.Windows.Forms.MessageBox.Show(ex.ToString, "Configurator", System.Windows.Forms.MessageBoxButtons.OK, System.Windows.Forms.MessageBoxIcon.Stop)
    	End Try
    End Using
     Thanx in advance
    Please use plain text.
    Distinguished Contributor
    Artvegas
    Re: Counting instances of an image
    05-29-2012 02:37 AM in reply to: btmsoftware
    You need to search for raster reference entities of type RasterImage. There are two options I know for this, depending on your requirements: 1. Use Editor.SelectAll(), passing in a SelectionFilter with the appropriate dxf code. This is easiest but will only work in the current layout. Note: You might also need to zoom extents for this to work, i can't remember if you need to. 2. Iterate your block table records looking for RasterImage entities, using a counter. Advantage with this approach is that you can iterate your model space as well as all of your paper space block table records - i.e. you will get all of them.
    Active Contributor
    05-29-2012 03:11 AM in reply to: Artvegas
    Will give option 2 a shot, seems the most appropriate indeed.
    If you happen to have an example for this iteration ,great, if not, I'll figure it out by myself ;-)
    ADN Support Specialist
    Virupaksha.aithal
    05-29-2012 04:41 AM in reply to: btmsoftware
    Hi
    Can you try DevBlog solution "Identifying number times a Raster Image is used in a drawing"
    http://adndevblog.typepad.com/autocad/2012/05/identifying-number-times-a-raster-images-is-used-in-a-...?
    Virupaksha aithal
    Autodesk Devloper Network
    Virupaksha Aithal KM
    Developer Technical Services
    Autodesk Developer Network
    Active Contributor
    05-29-2012 05:00 AM in reply to: Virupaksha.aithal
    Exactly what I needed, thanx a lot
