.NET
Active Contributor
yuh0317
Message 1 of 18 (3,159 Views)
Could not load file or assembly 'accoremgd.dll' or one of its dependencies.
3159 Views, 17 Replies
09-11-2012 07:42 PM
Hi All,
I want to create a silent acad process in background and do some works, it works well in AutoCAD 2012. But when I upgrade to AutoCAD 2013, it cannot works. I already had referenced accoremgd.dll. It compiles well, I get the errors "Could not load file or assembly 'accoremgd.dll' or one of its dependencies . The specified module could not be found." when I run my program. Who can tell me what dlls i lose to referenced.
Yu
Active Contributor
yuh0317
Message 2 of 18 (3,157 Views)
Re: Could not load file or assembly 'accoremgd.dll' or one of its dependencies.
09-11-2012 07:46 PM in reply to: yuh0317
The following dlls had been referenced.
accoremgd
acdbmgd
acmgd
Autodesk.AutoCAD.Interop
Autodesk.AutoCAD.Interop.Common
Yu
Valued Mentor
gasty1001
Message 3 of 18 (3,147 Views)
09-11-2012 09:01 PM in reply to: yuh0317
Is Copy Local set to false?
Gaston Nunez
Active Contributor
yuh0317
Message 4 of 18 (3,134 Views)
09-12-2012 12:48 AM in reply to: yuh0317
No matter the value is false or true. The issue is still reproducible.
Yu
Active Contributor
yuh0317
Message 5 of 18 (3,133 Views)
09-12-2012 01:23 AM in reply to: yuh0317
Autodesk.AutoCAD.DatabaseServices.Database db = new Autodesk.AutoCAD.DatabaseServices.Database(false, true);
I only create a database object, there is a exception message "Could not load file or assembly 'accoremgd, Version=19.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified."
AutoCAD 2013 32-bit.
I have attached sample codes.
Active Contributor
yuh0317
Message 6 of 18 (3,130 Views)
09-12-2012 01:24 AM in reply to: yuh0317
I add the following references
accoremgd
acdbmgd
acmgd
Moderator
Alexander.Rivilis
Message 7 of 18 (3,127 Views)
09-12-2012 01:55 AM in reply to: yuh0317
Are you trying to create standalone exe-file?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
yuh0317
Message 8 of 18 (3,115 Views)
09-12-2012 03:42 AM in reply to: Alexander.Rivilis
Yes, I want to create standalone exe-file. And run AutoCAD 2013 in the background in the silent mode.
Yu
Moderator
Alexander.Rivilis
Message 9 of 18 (3,114 Views)
09-12-2012 03:47 AM in reply to: yuh0317
Yu
It is impossible using acdbmgd.dll, acmgd.dll and accoremgd.dll in standalone exe-file.
Its can be using only in dll-file which loaded into AutoCAD.
So you can use:
Active Contributor
yuh0317
Message 10 of 18 (3,099 Views)
09-12-2012 04:59 AM in reply to: Alexander.Rivilis
Actually I want to use some class in the acdbmgd.dll, acmgd.dll and accoremgd.dll in standalone exe-file. Do you know any other ways to use some class in the acdbmgd.dll, acmgd.dll and accoremgd.dll except load my dlls by AutoCAD.
YU
You are not logged in.
Ask the Community
