• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    Copy .plt files to a plotter
    311 Views, 19 Replies
    04-04-2012 12:36 PM
    Hi
    I'm trying to copy plot files to a plotter with filecopy(plotfile,\\server\plottername) it works fine when I have the UNC address but there are network printers without this address that I need to copy files too. I have the IP addresses of these printers.Is there a way to send a file to an IP address?
    Thanks in advance
    Please use plain text.
    Valued Mentor
    Re: Copy .plt files to a plotter
    04-04-2012 01:56 PM in reply to: GeeHaa
    I have used FTP to do this with several HP devices.  I think all hp printers support ftp.  You can test it from the dos prompt with the following 6 lines:
    ftp <enter>
    open printer.ip.address
    <login> user
    <pword> guest
    put "your printfile"
    quit
    If that works, you can code an ftp transfer using the system.net namespace.  Post back if you want an example.
    04-04-2012 02:54 PM in reply to: fieldguy
    Thanks very much for the response.
    It lets me login but when I use the put command It gives me .550  the system cannot find the specified file.
    Im using  Put C:\lisp\X.plt   I tried it with quotes also. But I would like to see the code.
    Valued Mentor
    04-04-2012 03:29 PM in reply to: GeeHaa
    OK.  I will post it in the morning - miller time now.
    Try the script from the same folder (c:\lisp) with put "x.plt".
    Valued Contributor
    SENL1362
    04-04-2012 11:32 PM in reply to: GeeHaa
    This might help you
    From within DOS command:
    net use LPT1 \\PrinterIpAddress\lpr
    copy /b C:\temp\xxx.prn LPT1
    or
    lpr -S PrinterIpAddress -P printer -o l  c:\temp\xxx.prn
    04-05-2012 10:42 AM in reply to: GeeHaa
    I tried changing to the C:\lisp folder and using put "x.plt". Two lines come up, one says 200 Port command successful. The other says 550 The system cannot find the file specified . I tried using lpr but it comes up as an unrecognized command.
    Valued Mentor
    04-05-2012 11:01 AM in reply to: GeeHaa
    I am having trouble (error 550) coding the script.  In other words, I can manually ftp using open and put, but error 550 is persistent in .NET.  I checked my other app and it uploads TIF images to a KIP printer without issue but the same code will not work with my hp laser.
    There are examples on the internet (http://www.vbforums.com/showthread.php?t=468649) but I do not have the time to figure out why I cannot get that to work.
    I am leaning towards the "net use" suggestion from SENL1362.  I have used LPR before as well but can't remember where it came from.
    Sorry!
    04-05-2012 11:01 AM in reply to: fieldguy
    Oops the put command does work on HP plotters I was trying it on an Oce.
    Valued Contributor
    SENL1362
    04-05-2012 11:28 PM in reply to: GeeHaa
    using XP? changes are you did not install the Print Services for Unix.
    Add Windows components/other network file and print services.
    You'll need the i386 part of the xp installation disc.
    Valued Contributor
    SENL1362
    04-05-2012 11:38 PM in reply to: GeeHaa
    did you verify the ipadress of the printer ?
    try
    ping <ipadress>
    or
    telnet <ipadress>
    You can log in on these oce printers if you have a root password
    telnet XXXXXXX
    Trying XXX.XXX.XXX.XXX...
    Connected to XXX.XXX.XXX.XXX.
    Escape character is '^]'.
    Network Printer Server Version 5.6.3 (XXX.XXX.XXX.XXX)
    login: root
    Password: <root pw here>
    Welcome root user
    XXX.XXX.XXX.XXX:root> list sysinfo
