.NET
Distinguished Contributor
GeeHaa
Message 1 of 20 (651 Views)
Copy .plt files to a plotter
651 Views, 19 Replies
04-04-2012 12:36 PM
Hi
I'm trying to copy plot files to a plotter with filecopy(plotfile,\\server\plottername) it works fine when I have the UNC address but there are network printers without this address that I need to copy files too. I have the IP addresses of these printers.Is there a way to send a file to an IP address?
Thanks in advance
Valued Mentor
fieldguy
Message 2 of 20 (644 Views)
Re: Copy .plt files to a plotter
04-04-2012 01:56 PM in reply to: GeeHaa
I have used FTP to do this with several HP devices.  I think all hp printers support ftp.  You can test it from the dos prompt with the following 6 lines:
ftp <enter>
open printer.ip.address
<login> user
<pword> guest
put "your printfile"
quit
If that works, you can code an ftp transfer using the system.net namespace.  Post back if you want an example.
GeeHaa
Message 3 of 20 (638 Views)
04-04-2012 02:54 PM in reply to: fieldguy
Thanks very much for the response.
It lets me login but when I use the put command It gives me .550  the system cannot find the specified file.
Im using  Put C:\lisp\X.plt   I tried it with quotes also. But I would like to see the code.
Valued Mentor
fieldguy
Message 4 of 20 (636 Views)
04-04-2012 03:29 PM in reply to: GeeHaa
OK.  I will post it in the morning - miller time now.
Try the script from the same folder (c:\lisp) with put "x.plt".
SENL1362
Message 5 of 20 (625 Views)
04-04-2012 11:32 PM in reply to: GeeHaa
This might help you
From within DOS command:
net use LPT1 \\PrinterIpAddress\lpr
copy /b C:\temp\xxx.prn LPT1
or
lpr -S PrinterIpAddress -P printer -o l  c:\temp\xxx.prn
GeeHaa
Message 6 of 20 (611 Views)
04-05-2012 10:42 AM in reply to: GeeHaa
I tried changing to the C:\lisp folder and using put "x.plt". Two lines come up, one says 200 Port command successful. The other says 550 The system cannot find the file specified . I tried using lpr but it comes up as an unrecognized command.
Valued Mentor
fieldguy
Message 7 of 20 (608 Views)
04-05-2012 11:01 AM in reply to: GeeHaa
I am having trouble (error 550) coding the script.  In other words, I can manually ftp using open and put, but error 550 is persistent in .NET.  I checked my other app and it uploads TIF images to a KIP printer without issue but the same code will not work with my hp laser.
There are examples on the internet (http://www.vbforums.com/showthread.php?t=468649) but I do not have the time to figure out why I cannot get that to work.
I am leaning towards the "net use" suggestion from SENL1362.  I have used LPR before as well but can't remember where it came from.
Sorry!
GeeHaa
Message 8 of 20 (607 Views)
04-05-2012 11:01 AM in reply to: fieldguy
Oops the put command does work on HP plotters I was trying it on an Oce.
SENL1362
Message 9 of 20 (594 Views)
04-05-2012 11:28 PM in reply to: GeeHaa
using XP? changes are you did not install the Print Services for Unix.
Add Windows components/other network file and print services.
You'll need the i386 part of the xp installation disc.
SENL1362
Message 10 of 20 (590 Views)
04-05-2012 11:38 PM in reply to: GeeHaa
did you verify the ipadress of the printer ?
try
ping <ipadress>
or
telnet <ipadress>
You can log in on these oce printers if you have a root password
telnet XXXXXXX
Trying XXX.XXX.XXX.XXX...
Connected to XXX.XXX.XXX.XXX.
Escape character is '^]'.
Network Printer Server Version 5.6.3 (XXX.XXX.XXX.XXX)
login: root
Password: <root pw here>
Welcome root user
XXX.XXX.XXX.XXX:root> list sysinfo
You are not logged in.
Ask the Community
