.NET
Active Contributor
xdbk07
Message 1 of 5 (988 Views)
Copy block reference "same autocad" and change att value
988 Views, 4 Replies
02-26-2013 09:01 PM
Hi All,
Please help me to creat a copy of block definition like autocad (block display beside mouse when we move) and replace some text of attribute.
Moderator
Alexander.Rivilis
Message 2 of 5 (967 Views)
Re: Copy block reference "same autocad" and change att value
02-27-2013 12:58 AM in reply to: xdbk07
Using a jig from .NET to multiply insert AutoCAD blocks
Using a jig from .NET to multiply insert AutoCAD blocks - Part 2
Jigging an AutoCAD block with attributes using .NET
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
xdbk07
Message 3 of 5 (945 Views)
02-27-2013 06:52 PM in reply to: xdbk07
Thank for help. These code are really complex.
Valued Mentor
DiningPhilosopher
Message 4 of 5 (940 Views)
02-27-2013 07:29 PM in reply to: xdbk07
Your subject says copy block reference, but your message says copy block definition.
Which is it?
The DeepCloneObjects() method of the Database class is used to copy objects, so that's what you'd use for copying a block reference. Copying a block definition is a bit more complicated, but also involves the use of DeepCloneObjects()..
Active Contributor
xdbk07
Message 5 of 5 (934 Views)
02-27-2013 08:22 PM in reply to: DiningPhilosopher
I want copy a block and replace some text string of attribute definition. Here is Kean 's code:
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Internal
Namespace BlockJigTest
    Class BlockJig
        Inherits EntityJig
        Private mCenterPt As Point3d, mActualPoint As Point3d
        Public Sub New(br As BlockReference)
            MyBase.New(br)
            mCenterPt = br.Position
        End Sub
        Protected Overloads Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
            Dim jigOpts As New JigPromptPointOptions()
            jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NoZeroResponseAccepted Or UserInputControls.NoNegativeResponseAccepted)
            jigOpts.Message = vbLf & "Enter insert point: "
            Dim dres As PromptPointResult = prompts.AcquirePoint(jigOpts)
            If mActualPoint = dres.Value Then
                Return SamplerStatus.NoChange
            Else
            End If
            Return SamplerStatus.OK
        End Function
        Protected Overloads Overrides Function Update() As Boolean
            mCenterPt = mActualPoint
            Try
                DirectCast(Entity, BlockReference).Position = mCenterPt
            Catch generatedExceptionName As System.Exception
                Return False
            End Try
            Return True
        End Function
        Public Function GetEntity() As Entity
            Return Entity
        End Function
    End Class
    Public Class Commands
        <CommandMethod("BJIG")> _
        Public Sub CreateBlockWithJig()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            ' First let's get the name of the block
            Dim opts As New PromptStringOptions(vbLf & "Enter block name: ")
            Dim pr As PromptResult = ed.GetString(opts)
            If pr.Status = PromptStatus.OK Then
                Dim tr As Transaction = doc.TransactionManager.StartTransaction()
                Using tr
                    ' Then open the block table and check the
                    ' block definition exists
                    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                    If Not bt.Has(pr.StringResult) Then
                        ed.WriteMessage(vbLf & "Block not found.")
                    Else
                        Dim bdId As ObjectId = bt(pr.StringResult)
                        ' We loop until the jig is cancelled
                        While pr.Status = PromptStatus.OK
                            ' Create the block reference and
                            ' add it to the jig
                            Dim pt As New Point3d(0, 0, 0)
                            Dim br As New BlockReference(pt, bdId)
                            ' Start annot-scale support code
                            Dim bd As BlockTableRecord = DirectCast(tr.GetObject(bdId, OpenMode.ForRead), BlockTableRecord)
                            ' Using will dispose of the block definition
                            ' when no longer needed
                            Using bd
                                If bd.Annotative = AnnotativeStates.[True] Then
                                    Dim ocm As ObjectContextManager = db.ObjectContextManager
                                    Dim occ As ObjectContextCollection = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES")
                                    ObjectContexts.AddContext(br, occ.CurrentContext)
                                End If
                            End Using
                            ' End annot-scale support code
                            Dim entJig As New BlockJig(br)
                            ' Perform the jig operation
                            pr = ed.Drag(entJig)
                                ' If all is OK, let's go and add the
                                ' entity to the modelspace
                                Dim ms As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                                ms.AppendEntity(entJig.GetEntity())
                                tr.AddNewlyCreatedDBObject(entJig.GetEntity(), True)
                                ' Start attribute support code
                                bd = DirectCast(tr.GetObject(bdId, OpenMode.ForRead), BlockTableRecord)
                                ' Add the attributes
                                For Each attId As ObjectId In bd
                                    Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
                                    If TypeOf ent Is AttributeDefinition Then
                                        Dim ad As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                                        Dim ar As New AttributeReference()
                                        ar.SetAttributeFromBlock(ad, br.BlockTransform)
                                        br.AttributeCollection.AppendAttribute(ar)
                                        tr.AddNewlyCreatedDBObject(ar, True)
                                    End If
                                Next
                                ' End attribute support code
                                ' Call a function to make the graphics display
                                ' (otherwise it will only do so when we Commit)
                                doc.TransactionManager.QueueForGraphicsFlush()
                            End If
                        End While
                    End If
                    tr.Commit()
                End Using
            End If
        End Sub
    End Class
End Namespace
 It work OK but it is not what i need. I want to get the block by click it and edit textstring of attribute. It's really hard for me to do that. Please help me.
You are not logged in.
Ask the Community
