.NET
Active Member
Babak
Message 1 of 5 (143 Views)
Copy an Entity to another Layer
143 Views, 4 Replies
11-03-2006 11:08 PM
How can I copy an Entity to another layer? I have its ObjectID.
Any idea or comment?
Babak
*tp
Message 2 of 5 (143 Views)
Re: Copy an Entity to another Layer
11-04-2006 02:38 AM in reply to: Babak
Imports AcAp = Autodesk.AutoCAD.ApplicationServices
Imports AcDb = Autodesk.AutoCAD.DatabaseServices
_
Public Sub MyTest()
Dim ed As AcEd.Editor =
AcAp.Application.DocumentManager.MdiActiveDocument.Editor
Dim res As AcEd.PromptEntityResult = ed.GetEntity("Select Entity")
Dim id As AcDb.ObjectId = res.ObjectId
'Dim dl As AcAp.DocumentLock =
AcAp.Application.DocumentManager.MdiActiveDocument.LockDocument
Using db As AcDb.Database =
AcDb.HostApplicationServices.WorkingDatabase()
Using tr As AcDb.Transaction =
db.TransactionManager.StartTransaction
Dim ent As AcDb.Entity = tr.GetObject(id,
AcDb.OpenMode.ForWrite)
ent.Layer = "NewLayer"
tr.Commit()
End Using
End Using
'dl.Dispose()
End Sub
tp
escreveu na mensagem news:5385151@discussion.autodesk.com...
Babak
I'm protected by SpamBrave
http://www.spambrave.com/
Active Member
Babak
Message 3 of 5 (143 Views)
11-04-2006 09:40 AM in reply to: Babak
ٰThank you very much for your answer, but this code cuts the selected object and move it to NewLayer. I want to Copy it and have a copy of that object to another layer. Would you help me with this?
Thank you,
Babak
*tp
Message 4 of 5 (143 Views)
11-05-2006 05:39 AM in reply to: Babak
Hi, Babak
I hope it can help you
Imports AcEd = Autodesk.AutoCAD.EditorInput
Imports AcGe = Autodesk.AutoCAD.Geometry
Imports AcRx = Autodesk.AutoCAD.Runtime
Public Module Module1
_
Public Sub Copy2Layer()
AcAp.Application.DocumentManager.MdiActiveDocument.Editor()
ed.WriteMessage(vbLf & "Copy entities to layer")
Dim res As AcEd.PromptEntityResult = ed.GetEntity("Select entity")
If res.Status <> AcEd.PromptStatus.OK Then Exit Sub
Dim optp As New AcEd.PromptPointOptions(vbLf & "Copy from point")
Dim resp As AcEd.PromptPointResult = ed.GetPoint(optp)
If resp.Status <> AcEd.PromptStatus.OK Then Exit Sub
Dim fromPt As AcGe.Point3d = resp.Value
optp.Message = "To point"
optp.UseBasePoint = True
optp.BasePoint = fromPt
resp = ed.GetPoint(optp)
Dim toPt As AcGe.Point3d = resp.Value
Dim id As AcDb.ObjectId = Module1.CopyEntity(res.ObjectId, fromPt,
toPt)
Module1.ChangeLayer(id, "NewLayer")
End Sub
Friend Function CopyEntity(ByVal objID As AcDb.ObjectId, ByVal fromPt
As
AcGe.Point3d, ByVal toPt As AcGe.Point3d) As AcDb.ObjectId
If objID = Nothing Then Return Nothing
Dim id As AcDb.ObjectId = Nothing
Try
Dim v3d As New AcGe.Vector3d(toPt.X - fromPt.X, toPt.Y -
fromPt.Y, toPt.Z - fromPt.Z)
Dim m3d As AcGe.Matrix3d = AcGe.Matrix3d.Displacement(v3d)
Using btr As AcDb.BlockTableRecord =
tr.GetObject(db.CurrentSpaceId, AcDb.OpenMode.ForWrite, False)
Dim ent As AcDb.Entity = tr.GetObject(objID,
AcDb.OpenMode.ForRead, False)
Dim e As AcDb.Entity = ent.GetTransformedCopy(m3d)
id = btr.AppendEntity(e)
db.TransactionManager.AddNewlyCreatedDBObject(e, True)
tr.Commit()
End Using
Catch ex As Exception
tr.Abort()
End Try
End Using
End Using
Return id
End Function
Friend Sub ChangeLayer(ByVal objID As AcDb.ObjectId, ByVal newLayer As
String)
AcAp.Application.DocumentManager.MdiActiveDocument.LockDocument()
db.TransactionManager.StartTransaction()
ent.Layer = newLayer
tr.Commit()
End Using
End Using
'dl.Dispose()
End Sub
End Module
tp
escreveu na mensagem news:5385306@discussion.autodesk.com...
?Thank you very much for your answer, but this code cuts the selected
object
to
Thank you,
Babak
Active Member
Babak
Message 5 of 5 (143 Views)
11-06-2006 12:01 PM in reply to: Babak
Thank you very much,
It works perfectly :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
