• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Coordinates of Vertices of Region-Objects in AutoCAD
    184 Views, 3 Replies
    09-14-2005 03:58 AM
    I want to handle Region-Objects in AutoCAD. One issue is, I want to read the coordinates of the vertices. When I start an Iterator (with VBA or C#), I can’t detect an order, in which the vertices are covered.
    Does anybody know, in which order the vertices are covered? It would be very helpful!
    Jochen
    Please use plain text.
    *Albert Szilvasy
    Re: Coordinates of Vertices of Region-Objects in AutoCAD
    09-16-2005 03:42 PM in reply to: joc007
    What iterator are you talking about?
    Albert
    wrote in message news:4955678@discussion.autodesk.com...
    can't detect an order, in which the vertices are covered.
    helpful!
    Jochen
    09-19-2005 02:31 AM in reply to: joc007
    The problem is as follows:
    We are iterating over all entities in a drawing and on finding a region we explode it. What we get back from the explode method is an array of AcadLine objects. But if we iterate over this array the AcadLine objects are not, at least to our concern, returned in any particular order. Is this true, or do we just missing something?
    The reason we want to know the exact order is that we are trying to convert the region into a polyline of the exact same shape.
    Thanks for any help.
    *Albert Szilvasy
    09-19-2005 09:01 PM in reply to: joc007
    That maybe so but it shouldn't prevent you from doing what you'd like to do.
    You simply have to order them based on coincident vertices.
    Albert
    wrote in message news:4959935@discussion.autodesk.com...
