• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Accepted Solution
    Convert .dwg to .bmp in AutoCAD 2013
    294 Views, 5 Replies
    11-20-2012 03:12 AM
      I want to convert the .dwg file to .bmp in AutoCAD 2013 using interop services in API
    I have a code to perform this in AutoCAD 2012 but that is not working fine in AutoCAD 2013. Can anyone help me in this regarding.
    This is what i tried
    AcadSelectionSet oSS = null;
    short[] ftype = new short[1];
    ftype[0] = 410;
    object[] fdata = new object[1];
    fdata[0] = "Model";
    acadapp.ZoomExtents();
    oSS = _acadapp.ActiveDocument.SelectionSets.Add("MySet");
    oSS.Select(AcSelect.acSelectionSetAll, null, null, ftype, fdata);
    acadapp.ActiveDocument.Export(OutputFileName, "BMP", oSS);
    Please use plain text.
    *Expert Elite*
    Re: Convert .dwg to .bmp in AutoCAD 2013
    11-20-2012 04:21 AM in reply to: chockalingam
    use the plot-functionality, that gives you more options (espcially the resolution) for the output.
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Contributor
    11-20-2012 04:26 AM in reply to: alfred.neswadba
    Can you guide me how to do that.... Since i am not much familiar with that
    *Expert Elite*
    11-20-2012 04:45 AM in reply to: chockalingam
    create a new plotter (with the new plotter-wzard) that creates raster-files (>>>details<<<)
    Then search for source-code controlling plotting, e.g. >>>click<<<.
    - alfred -
    Alfred NESWADBA
    Contributor ow
    11-20-2012 04:59 AM in reply to: chockalingam
    Or you can send the BMPOUT command to the commandline.
    Active Contributor
    11-20-2012 05:29 AM in reply to: chockalingam
    Hi all,
    Finally Found Solution, the code i used is follows
    ftype[0] = 410;
    fdata[0] = "Model";
    _acadapp.ZoomExtents();
    _acadapp.ActiveDocument.Export(OutputFileName, "BMP", oSS);
    KillAcadDocuments(_acadapp);
    just send the selection set as null, this is Exporting the BMP.
    Thanks all for helping me...
