.NET
Convert Layer Problem
6 REPLIES 6
gilseorin
181 Views, 6 Replies
Hi,all.
My problem is to convert selected layer to current layer.
Some help?
Thanks in advance.
6 REPLIES 6
MarkPendergraft
in reply to: gilseorin
all you need to do is get the object id of the selected layer, and then set it as the current layer....
Public Sub SetLayer()
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
CreateLayerSelectForm()
Using trans As Transaction = db.TransactionManager.StartTransaction
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForRead, False, True)
Dim ltr As LayerTableRecord = Nothing
If lt.Has(returnlayname) Then
ltr = trans.GetObject(lt.Item(returnlayname), OpenMode.ForWrite, False, True)
If Not db.Clayer = ltr.ObjectId Then
ltr.IsFrozen = False
ltr.IsLocked = False
ltr.IsOff = False
ElseIf ReturnLayName "" Then
ed.WriteMessage(vbCrLf + "The layer '" + ReturnLayName + "' does not exist.")
Exit Sub
trans.Commit()
ReturnLayName = ""
End Using
End Sub
this example is a program i have written. the line :
calls a form into being, with all the layers in the drawing loaded into it, then it allows you to select one, and returns the string of the layer name as the public shared value ReturnLayName. if the layer exists (lt.has(returnlayname) ) then it makes sure it isn't off, frozen, or locked, and then sets it.
Hope this helps.
gilseorin
Thanks for the reply, but it's not for me.
It has no contents of converting to current layer.
What I need is the next code of the following code.
Plz, give me a hand.
Dim db As Database = Application.DocumentManager.MdiActiveDocument.Database
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Try
Dim entselopt As PromptEntityOptions = New PromptEntityOptions("" & Microsoft.VisualBasic.Chr(10) & "Select Entity: ")
entselopt.SetRejectMessage("" & Microsoft.VisualBasic.Chr(10) & "Entity NOt Selected!")
entselopt.AddAllowedClass(GetType(DBText), True)
Dim entselres As PromptEntityResult = ed.GetEntity(entselopt)
Dim Ent As Entity = CType(tr.GetObject(entselres.ObjectId, OpenMode.ForRead), Entity)
Dim returnlayname As String = Ent.Layer
tr.Commit()
Finally
tr.Dispose()
End Try
MarkPendergraft
Public Sub testing()
Try
Dim entselopt As PromptEntityOptions = New PromptEntityOptions(vbCrLf + "Select Entity: ")
entselopt.AllowNone = False
entselopt.AllowObjectOnLockedLayer = True
If entselres.Status <> PromptStatus.OK Then Exit Sub
Dim Ent As Entity = trans.GetObject(entselres.ObjectId, OpenMode.ForRead, False, True)
Dim ltr As LayerTableRecord = trans.GetObject(lt.Item(Ent.Layer), OpenMode.ForWrite, False, True)
ltr.IsOff = False
trans.Commit()
End Using
Catch ex As Exception
ed.WriteMessage("Error: " + ex.Message)
End Try
End Sub
gilseorin
It seemes to be my fault.
Pardon my short expression.
What I need is to convert selected layer to current layer.
If existing layers are "0" and "layer1" and "layer2" and also
if selected layer is "layer1" and also
If current layer is "0" then the result should be as follows.
selected layer("layer1") ----> layer "0"
Finally, existing layers are "0" and "layer2".
MarkPendergraft
Public Sub ChangeLayerToCurrent()
Try
Dim ent As Entity = trans.GetObject(entselres.ObjectId, OpenMode.ForRead, False, True)
Dim entlayer As String = ent.Layer : ent = Nothing
Dim ltr As LayerTableRecord = trans.GetObject(db.Clayer, OpenMode.ForRead, False, True)
Dim Values() As TypedValue = {New TypedValue(DxfCode.LayerName, entlayer)}
Dim prFilter As SelectionFilter = New SelectionFilter(Values)
Dim prSelRes As PromptSelectionResult = ed.SelectAll(prFilter)
If prSelRes.Status <> PromptStatus.OK Then Exit Sub
Dim selset As SelectionSet = prSelRes.Value
Dim ids() As ObjectId = selset.GetObjectIds
Dim id As ObjectId
For Each id In ids
ent = trans.GetObject(id, OpenMode.ForWrite, False, True)
ent.Layer = ltr.Name
Next
ltr = trans.GetObject(lt.Item(entlayer), OpenMode.ForWrite, False, True)
ltr.Erase()
trans.Commit()
End Using
End Try
End Sub
gilseorin
Thank you so---ooooooooooooo much.
I deeply appreciate for your help.
Thank you again. Happy Day!
”Boost
