Show only
Search instead for
Is it possible to connect two block's with a line, and when we move any of the one block the connectivity must also move along with it without disconnecting from the other block, - is it possible to do this programmatically using .Net......?.....thank's in advance
U can use a dynamic block as the connector between the teo blocks and when one of the blocks is pulled the other end would automatically gets extended.
Kamala, ya it may be, but i want is as a real electrical wire, when a block is moved in any direction it must be flexible to bend and turn, have U seen 'Connector' in Microsoft Visio, it's like that. thank's
