.NET
Connecting to the existing ACAD instance
2 REPLIES 2
220 Views, 2 Replies
'm trying to connect to the existing ACAD 2006 instance from a VB.net project using the com interop object.
I'm using the following code:
Dim myApp As AcadApplication
myApp = GetObject(, "Autocad.Application")
myApp.Visible = True
The code keeps returning a NEW instance of ACAD. I want to tap into the EXISTING instance.
Can someone tell me what's wrong?
thanks,
mark c.
Phoenix
2 REPLIES 2
GetActiveObject("AutoCAD.Application.16.2")
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
what do you have to reference to make this work? I am totally new to AutoCAD and I can't get even this little launch code to work.
Thanx
”Boost
