.NET
Connectd Lines and Arcs
2 REPLIES 2
albazel2004
392 Views, 2 Replies
Using VB.NET
How to draw connected line arc line arc line and so on, given some points formatted in a file like this
easting        northing             radius
0                 0
10               10                      200.00
12               10                      150.00
30               20                      60.00
50               30                      50.00
50               43                      60.00
1640.42      1104.30             50.00
1770.20      1100.62            100.00
1850.00      1085.18            100.00
2002.61      1141.46
the output will be like this :
line arc line arc line arc line arc line arc line arc line arc line arc line
2 REPLIES 2
Hallex
in reply to: albazel2004
You can start from this code, gathered from many autors:
#Region "Select connected lines and arcs"
        <CommandMethod("arclines", CommandFlags.UsePickSet)> _
        Public Sub LoopGetEntity()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim oids() As ObjectId = GetUserPickedObjects(doc, "Select line or arc one by another: ")
            ed.Regen()
            Dim sb As StringBuilder = New StringBuilder
            Dim txtfile = Path.Combine("C:\Test\", "my_lines_and_arcs.csv") '<-- change directory name and file name here
            Using tr As Transaction = doc.Database.TransactionManager.StartTransaction()
                Dim txtLine As String = ""
                For Each id As ObjectId In oids
                    Dim ent As DBObject = tr.GetObject(id, OpenMode.ForRead, False)
                    If TypeOf (ent) Is Arc Then
                        Dim arc As Arc = TryCast(ent, Arc)
                        If arc Is Nothing Then Return
                        Dim sp As Point3d = arc.StartPoint
                        Dim ep As Point3d = arc.EndPoint
                        Dim rad As Double = arc.Radius
                        txtLine = String.Format("{0:f3}" + vbTab + "{1:f3}" + vbTab + "{2:f3}" + vbTab + "{3:f3}" + vbTab + "{4:f3}", sp.X, sp.Y, ep.X, ep.Y, rad)
                        sb.AppendLine(txtLine)
                    Else
                        Dim ln As Line = TryCast(ent, Line)
                        If ln Is Nothing Then Return
                        Dim sp As Point3d = ln.StartPoint
                        Dim ep As Point3d = ln.EndPoint
                        txtLine = String.Format("{0:f3}" + vbTab + "{1:f3}" + vbTab + "{2:f3}" + vbTab + "{3:f3}" + vbTab + "{4:f3}", sp.X, sp.Y, ep.X, ep.Y, String.Empty)
                Next
            End Using
            Try
                Using sw As New StreamWriter(txtfile, False, Encoding.Default)
                    sw.Write(sb.ToString())
                    sw.Close()
                End Using
            Catch
            Finally
                System.Diagnostics.Process.Start(txtfile)
            End Try
        End Sub
        Private Shared Function GetUserPickedObjects(ByVal doc As Document, msg As String) As ObjectId()
            Dim ids As New List(Of ObjectId)
                Dim go As Boolean = True
                While go
                    go = False
                    Dim opt As New PromptEntityOptions(vbLf & msg)
                    opt.SetRejectMessage(vbLf + "You have to select line or arc only!")
                    opt.AddAllowedClass(GetType(Line), False)
                    opt.AddAllowedClass(GetType(Arc), False)
                    Dim res As PromptEntityResult = doc.Editor.GetEntity(opt)
                    If res.Status = PromptStatus.OK Then
                        Dim exists As Boolean = False
                        For Each id As ObjectId In ids
                            If id = res.ObjectId Then
                                exists = True
                                Exit For
                        Next
                        If Not exists Then
                            'Highlight
                            Dim ent As Entity = DirectCast(tr.GetObject(res.ObjectId, OpenMode.ForWrite), Entity)
                            ent.Highlight()
                            ids.Add(res.ObjectId)
                            go = True
                End While
                tr.Commit()
            End Using
            Return ids.ToArray()
        End Function
#End Region
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
BKSpurgeon
in reply to: Hallex
”Boost
