.NET
Valued Contributor
dynamicscope
Message 11 of 13 (184 Views)
Re: CommandEnded Event handling with OVERKILL
02-03-2013 09:45 PM in reply to: Alexander.Rivilis
HI, Alex.
I have tried one that you suggested with the following code.
private void SelectEntitiesOnLayer(Document doc, string layerName)
    Editor ed = doc.Editor;
    // Build a filter list so that only entities
    // on the specified layer are selected
    //TypedValue[] tvs = new TypedValue[1] { new TypedValue((int)DxfCode.LayerName, layerName) };
    TypedValue[] tvs = new TypedValue[2] { new TypedValue((int)DxfCode.LayerName, layerName), new TypedValue((int)DxfCode.LayoutName, "Model") };
    SelectionFilter sf = new SelectionFilter(tvs);
    PromptSelectionResult psr = ed.SelectAll(sf);
[CommandMethod("MyOverkill")]
public void MyOverkill()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    SelectEntitiesOnLayer(doc, LayerName.TIN);
    doc.SendStringToExecute("-overkill\np\n\n\n", true, false, false);
[CommandMethod("MoreWork")]
public void MoreWork()
    DoSomeWork();
[CommandMethod("Test")]
public void Test()
    string cmd = @"(command ""MyOverkill"")(while(>(getvar ""cmdactive"")0)(command pause))(command ""MoreWork"") ";
    doc.SendStringToExecute(cmd, true, false, true);
As you can see, I am expecting DoSomeWork() gets called after "MyOverkill"
Let's say DoSomeWork() is nothing more than poping up the alert.
If I call "Test" command the aleart box pops up immediately, then "-overkill" gets called after.
Which is opposite to what I expected.
Did I do something wrong? =(
Moderator
Alexander.Rivilis
Message 12 of 13 (179 Views)
02-03-2013 10:56 PM in reply to: dynamicscope
What about this code:
public void Test()
    string cmd;
    cmd = "-overkill\n_p\n\n\n";
    cmd = "(while(>(getvar \"cmdactive\")0)(command pause))\n";
    cmd = "MoreWork\n";
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
dynamicscope
Message 13 of 13 (172 Views)
02-04-2013 01:24 AM in reply to: Alexander.Rivilis
Thank you, Alex~!!
Super awesome~!
Looks like this code is working~!! =)
You are not logged in.
Ask the Community
