Command for insert block.
Any body, can you please give me the command  for Insert block with file name.
using .net code (SendStringToExecute)
Raman
Isn't it just SendStringToExecute("_.insert ", true,false,false)
-Ted
this looks gud.
But i need to pass file name (.dwg file) as paramter to to this command (insert).
So, how i can use this in SendStringToExecute("_.insert ", true,false,false)
Please advice...
Raman
_gile
Hi
The SendStringToExecute first argument have to be the same as inputs at command line IOW the same as script (.scr) content.
SendStringToExecute(@"_.insert "F\Blocks\Block.dwg" ", true,false,false);
Gilles Chanteau
GileCAD
GitHub
