Command Line Args from Network File?
Message 1 of 1
I've got a VB.NET application that converts PDFs to
TIFs. It works fine with all files using the dialog box interface, but I thought
I'd go crazy and add a right-click menu option. When I try this right click
option locally, it works just fine.  When I try in on a file located on the
network, it won't pick up the file name or path like it does from a local file.
Anyone have any tips for getting this to work?  the Command Line Arg
function I'm using is below...
Thanks for any help!
Module
subMain
Public frmSingleFile
As
color=#0000ff size=2>New
frmSingleFile
Public frmPDF2TIF
As
frmPDF2TIF
Public CLA
color=#0000ff size=2>As
size=2>String
Public CLFolder
As
color=#0000ff size=2>String
Sub Main()
Dim x
size=2>Integer
If
Len(GetCommandLineArgs(0)) > 0
size=2>Then
GetCommandLineArgs()
If
UBound(GetCommandLineArgs) > 0
size=2>Then
For x = 0
color=#0000ff size=2>To
CLA = CLA & " " & GetCommandLineArgs(x)
Next
MsgBox(CLA)           'for
testing
CLFolder = Trim(Left(CLA, InStrRev(CLA, "\")))
CLFolder = Right(CLFolder, Len(CLFolder) - 1)
'MsgBox(CLFolder)
color=#000000>
'for
testing
End
color=#0000ff size=2>If
MsgBox(CLA)            'for
testing
MsgBox(CLFolder)    'for testing
frmSingleFile.ShowDialog()
Else
frmPDF2TIF.ShowDialog()
End
End
color=#0000ff size=2>Sub
Public
color=#0000ff size=2>Function
As
' Declare variables.
size=2>
Dim separators
As
Dim commands
As
Microsoft.VisualBasic.Command()
Dim args()
size=2>String
= commands.Split(separators.ToCharArray)
Return args
End
End
size=2>Module
Replies (0)
