CloseAndSave problem
The following replaces all blocks with a file form disk then synchronises
attributes:-
Public Sub RefreshBlocks()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Using docLock As DocumentLock =
Application.DocumentManager.MdiActiveDocument.LockDocument()
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Try
If
'code to replace blocks here
trans.Commit()
Catch ex As System.Exception
MsgBox(ex.Message)
Finally
trans.Dispose()
End Try
doc.SendStringToExecute("_attsync n *" & ControlChars.Cr, True, False,
False)
ed.Regen()
End Using
End Sub
This works perfectly well, but if I call it from a routine that opens a file
it all works except the attsync. The blocks actually get swapped and if I
exit the loop before the doc.closeandsave line the attributes actually
update. It's probably something basic but it's baffled me:-
Sub ProcessAllDWGS()
Try
Dim dir As New DirectoryInfo("L:\work\ASDA\StoreSpace\Drawings\Final
QA")
Dim files() As FileInfo
files = dir.GetFiles("*.dwg")
For Each file As FileInfo In files
Application.DocumentManager.Open(file.FullName, False)
RefreshBlocks()
doc.CloseAndSave(file.FullName)
doc.Dispose()
Next
MsgBox(ex.Message)
End Try
End Sub
Regards
Dave Preston
Reading this newsgroup and searching (if you can, that is)
on
the phrase 'SendStringToExecute' might help.
SendStringToExecute() is just like VBA's SendCommand(),
it's
asynchronous, meaning that it returns before the commands
that
you pass it have finished.
For that reason, I seriously doubt that what you're
attempting
to do is going to work.
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000
through 2009
href="http://www.acadxtabs.com">http://www.acadxtabs.com
The
attributes:-
    Using
    Dim ed As Editor =
doc.Editor
Try
        If
'code to
replace blocks here
        End
If
trans.Commit()
    Catch ex As
System.Exception
MsgBox(ex.Message)
    Finally
trans.Dispose()
    End Try
False)
    ed.Regen()
    End
Using
End Sub
Sub
ProcessAllDWGS()
Try
        Dim dir As New
QA")
        Dim files() As
FileInfo
        files =
        For
files
False)
RefreshBlocks()
doc.Dispose()
Next
    Catch ex As
System.Exception
MsgBox(ex.Message)
    End Try
End
Sub
Regards
Dave Preston
Many thanks Tony, as ever. Is there a programmatic
equivalent of attsync or a workaround you can think of?
Regards
Dave Preston
on
it's
that
attempting
through 2009
The
attributes:-
    Dim ed As Editor
= doc.Editor
Try
        If
'code to
replace blocks here
        End
If
trans.Commit()
    Catch ex As
System.Exception
MsgBox(ex.Message)
Finally
    trans.Dispose()
End Try
False)
ed.Regen()
    End Using
End
Sub
it's baffled me:-
Try
        Dim dir As New
QA")
        Dim files() As
FileInfo
        files =
        For
files
False)
RefreshBlocks()
doc.Dispose()
Next
    Catch ex As
System.Exception
MsgBox(ex.Message)
    End Try
End
Sub
Regards
Dave
Preston
I suppose I could run ScriptPro on all files and
just do the attsync in a script file
Regards
Dave Preston
programmatic equivalent of attsync or a workaround you can think
of?
Regards
Dave Preston
on
it's
that
attempting
Supporting AutoCAD
2000 through 2009
The
attributes:-
Public Sub
RefreshBlocks()
    Dim ed As
Editor = doc.Editor
Try
        If
'code to
replace blocks here
        End
If
trans.Commit()
    Catch ex As
System.Exception
MsgBox(ex.Message)
Finally
trans.Dispose()
    End
Try
False)
ed.Regen()
    End Using
End
Sub
Sub
ProcessAllDWGS()
Try
        Dim dir As New
QA")
        Dim files() As
FileInfo
        files =
files
False)
RefreshBlocks()
doc.Dispose()
Next
    Catch ex As
System.Exception
MsgBox(ex.Message)
    End Try
End
Sub
Regards
Dave
Preston
Aside from writing your own attsync, I think the
only
alternative is script pro.
through 2009
of?
Regards
Dave Preston
on
it's
that
attempting
Supporting AutoCAD
2000 through 2009
The
attributes:-
Public Sub
RefreshBlocks()
    Dim ed As
Editor = doc.Editor
Try
        If
'code to
replace blocks here
        End
If
trans.Commit()
    Catch ex As
System.Exception
MsgBox(ex.Message)
Finally
trans.Dispose()
    End
Try
False)
ed.Regen()
    End Using
End
Sub
Sub
ProcessAllDWGS()
Try
        Dim dir As New
QA")
        Dim files() As
FileInfo
        files =
files
False)
RefreshBlocks()
doc.Dispose()
Next
    Catch ex As
System.Exception
MsgBox(ex.Message)
    End Try
End
Sub
Regards
Dave
Preston
I've already run the first phase that swaps the
blocks on 500+ files
The problem with ScriptPro is that it is slow.
Never mind, thanks for your help Tony
Regards
Dave Preston
only
through 2009
of?
Regards
Dave Preston
is) on
help.
it's
commands that
attempting
Supporting AutoCAD
2000 through 2009
The
attributes:-
Public Sub
RefreshBlocks()
    Dim ed As
Editor = doc.Editor
Try
        If
'code to
replace blocks here
trans.Commit()
    Catch ex As
System.Exception
MsgBox(ex.Message)
Finally
trans.Dispose()
    End
Try
False)
ed.Regen()
    End Using
End
Sub
Sub
ProcessAllDWGS()
Try
        Dim dir As New
QA")
        Dim files()
As FileInfo
        files =
files
False)
RefreshBlocks()
doc.Dispose()
Next
    Catch ex As
System.Exception
MsgBox(ex.Message)
    End Try
End
Sub
Regards
Dave
Preston
