• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Distinguished Contributor
    SRSDS
    Check if file open
    175 Views, 4 Replies
    03-15-2012 01:36 PM
    I need to export data to an excel file but I need to check if the file is already open.
    Searching the internet I found this but I don't know what "imports" to use to use to enable it.
        Public Function FileInUse(ByVal sFile As String) As Boolean
            If System.IO.File.Exists(sFile) Then
                Try
                    Dim F As Short = FreeFile()
                    FileOpen(F, sFile, OpenMode.Binary, OpenAccess.ReadWrite, OpenShare.LockReadWrite)
                    FileClose(F)
                Catch
                    Return True
                End Try
            End If
        End Function
    Please use plain text.
    Re: Check if file open
    03-15-2012 01:42 PM in reply to: SRSDS
    Looks like you need to import Microsoft.VisualBasic to get the FileOpen and FileClose functions. You may want to change them to use IO.File.Open and IO.File.Close though, to get away from the old VB syntax.
    Brent McAnney
    Hallex
    03-15-2012 02:08 PM in reply to: SRSDS
    I don't know what is the namespaces you use
    in your program to work with Excel
    Anyway you may want to try this function as well
       'Imports Microsoft.Office.Interop.Excel
        'Imports Excel = Microsoft.Office.Interop.Excel
        Public Function IsExcelFileOpen(xlapp As Microsoft.Office.Interop.Excel.Application, filename As String) As Boolean
            Dim isopen As Boolean = True
            Dim wbook As Microsoft.Office.Interop.Excel.Workbook
            Try
                wbook = xlapp.Workbooks(filename)
            Catch
                isopen = False
            End Try
            Return isopen
        End Function
    ~'J'~
    SRSDS
    03-15-2012 02:11 PM in reply to: BMcAnney
    I added Imports Microsoft.VisualBasic but it didn't support the problem
    OpenMode.Binary is the only one it has a problem with it seems.
    arcticad
    03-15-2012 02:22 PM in reply to: SRSDS
    Microsoft.VisualBasic.OpenMode.Binary
    “We don’t have a snowball’s chance in a blast furnace of surviving this attack unless every one of our units gets into the fight right now!”
