.NET
Active Contributor
btmcad
Message 1 of 5 (547 Views)
Changing the document window size with vb.net
547 Views, 4 Replies
09-20-2012 01:33 PM
I'm trying to change the active document window size with vb.net. This seems like it should be straightforward, but I'm having some trouble. Below is some code that I tried to use which I found on the AutoCAD DevBlog.. I thought I understood how this works, but I can't seem to import the correct references to make it work. Any help would be greatly appreciated.
  Dim doc As Document = Application.DocumentManager.MdiActiveDocument()
            Dim docWindow As Window = doc.Window
            Dim size As Size = docWindow.Size
            docWindow.WindowState = Window.State.Normal
            docWindow.Size = New Size(500, 500)
arcticad
Message 2 of 5 (542 Views)
Re: Changing the document window size with vb.net
09-20-2012 02:19 PM in reply to: btmcad
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Windows
and changed size to drawing,size and it worked fine. in 2010
What was the error?
(defun botsbuildbots() (botsbuildbots))
Valued Mentor
fieldguy
Message 3 of 5 (534 Views)
09-20-2012 03:00 PM in reply to: btmcad
This works in Map 3D 2011.  References are attached.
<CommandMethod("testwindow")> _
    Public Sub testwindowsize()
        Dim doc As acapp.Document = acapp.Application.DocumentManager.MdiActiveDocument()
        Dim size As Drawing.Size = docWindow.Size
        docWindow.Size = New Drawing.Size(500, 500)
    End Sub
Active Contributor
btmcad
Message 4 of 5 (507 Views)
09-21-2012 03:50 AM in reply to: fieldguy
Thanks for the help, but it won't build with 2013.
I checked, and I have all of the references that fieldguy has. With acad 2013, I know a number of items have changed in .net. I've tried a number of combinations of imported namespaces, but I get a message stating that 'Type Size is not defined".
I can get this to work in earlier versions, but unfortunately, I need it to work in 2013.
btm
Valued Mentor
DiningPhilosopher
Message 5 of 5 (491 Views)
09-21-2012 11:47 AM in reply to: btmcad
There's a lot of changes in AutoCAD 2013 that break existing code.
See my response to your Swamp Post:
You are not logged in.
Ask the Community
