• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Changing the Color, Line type and Line weight using .Net
    471 Views, 9 Replies
    03-08-2012 04:37 AM
    How to change the Color, line type and Line weight for the Line using .Net.
    Please use plain text.
    Valued Mentor
    KerryBrown
    Re: Changing the Color, Line type and Line weight using .Net
    03-08-2012 04:45 AM in reply to: chockalingam
    What have you tried. ?
    ... and what documentation have you looked at ?
    class keyThumper<T> : Lazy<T>;      another  Swamper
    I do not endorse the social media app links below:smileyembarrassed:
    Active Contributor
    03-08-2012 04:50 AM in reply to: KerryBrown
    I tried the following
    newentLine.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 190)
    where, newentLine is a entity
    This works,  but the issue is i want to change the color with a string input. I don't know how to do it
    Valued Mentor
    KerryBrown
    03-08-2012 04:56 AM in reply to: chockalingam
    What strings do you want to use ?
    Active Contributor
    03-08-2012 04:57 AM in reply to: chockalingam
    I want to send the color as string
    ex: red, white, ByLayer........
    Valued Mentor
    KerryBrown
    03-08-2012 05:18 AM in reply to: chockalingam
    Sounds like a simple
    if (..)
    else if ( .. )
    else if ( .. )
    else if ( .. )
    else ( .. )
    construct would work for you.
    ... or you could use a dictionary if you're comfortable with that.
    Depending on the source of the string you may be advised to change the case to a consistant format ....
    Regards
    dgorsman
    03-08-2012 10:33 AM in reply to: KerryBrown
    Or a (switch...), since color values are mutually exclusive.  The various case statements would associate the strings with the enumerated values, or ACI values.
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Mentor
    KerryBrown
    03-08-2012 04:26 PM in reply to: chockalingam
    One option:
    Code solution is posted at  http://www.theswamp.org/index.php?topic=41172.msg463389#msg463389
    // (C) CodeHimBelonga kdub
    using System;
    using System.Windows;
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Runtime;
    using StringToColorTest;
    using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
    [assembly: CommandClass(typeof (StringToColor))]
    namespace StringToColorTest
        public class StringToColor
            [CommandMethod("DoIt")]
            public void StringToColorTest_01()
                Editor ed           = AcadApp.DocumentManager.MdiActiveDocument.Editor;
                string colorString  = AskUserForColorString(ed);
                int colorIndex      = ColorIndexFromString(colorString);
                MessageBox.Show( "Color String : " +
                                            colorString +
                                            "\nTranslates to Integer : " +
                                            colorIndex.ToString(),
                                  "StringToColorTest_01");
            public string AskUserForColorString(Editor ed)
                PromptStringOptions strOpts = new PromptStringOptions("\nEnter Color: ");
                strOpts.AllowSpaces         = false;
                PromptResult res            = ed.GetString(strOpts);
                if (res.Status != PromptStatus.OK)
                    return "ByLayer";
                return res.StringResult;
            public int ColorIndexFromString(string colorString)
                int result = -1;
                if (int.TryParse(colorString, out result))
                    result = ((result >= 0) && (result <= 256) ? result : 256);
                else
                    try
                        MyColors colorIndex =
                            (MyColors) Enum.Parse(typeof (MyColors), colorString, true);
                        if (Enum.IsDefined(typeof(MyColors), colorIndex))
                            result = (int) colorIndex;
                    catch (ArgumentException)
                        AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
        "Blooper !!");
                        return 256;
                return result;
            private enum MyColors
                ByBlock = 0,
                Red     = 1,
                Yellow  = 2,
                Green   = 3,
                Cyan    = 4,
                Blue    = 5,
                Magenta = 6,
                White   = 7,
                Grey    = 8,
                ByLayer = 256
    Active Contributor
    03-08-2012 08:03 PM in reply to: chockalingam
    Thanks for solution, this code helps me................
    Valued Mentor
    KerryBrown
    03-09-2012 05:49 PM in reply to: chockalingam
    You're welcome.
    It was an interesting technical problem.
    Regards
