.NET
.NET
Valued Contributor
chockalingam
Message 1 of 10 (1,146 Views)
Changing the Color, Line type and Line weight using .Net
1146 Views, 9 Replies
03-08-2012 04:37 AM
How to change the Color, line type and Line weight for the Line using .Net.
Valued Mentor
KerryBrown
Message 2 of 10 (1,142 Views)
Re: Changing the Color, Line type and Line weight using .Net
03-08-2012 04:45 AM in reply to: chockalingam
What have you tried. ?
... and what documentation have you looked at ?
class keyThumper<T> : Lazy<T>;      another  Swamper
Valued Contributor
chockalingam
Message 3 of 10 (1,137 Views)
03-08-2012 04:50 AM in reply to: KerryBrown
I tried the following
newentLine.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 190)
where, newentLine is a entity
This works,  but the issue is i want to change the color with a string input. I don't know how to do it
Valued Mentor
KerryBrown
Message 4 of 10 (1,126 Views)
03-08-2012 04:56 AM in reply to: chockalingam
What strings do you want to use ?
Valued Contributor
chockalingam
Message 5 of 10 (1,124 Views)
03-08-2012 04:57 AM in reply to: chockalingam
I want to send the color as string
ex: red, white, ByLayer........
Valued Mentor
KerryBrown
Message 6 of 10 (1,110 Views)
03-08-2012 05:18 AM in reply to: chockalingam
Sounds like a simple
if (..)
else if ( .. )
else if ( .. )
else if ( .. )
else ( .. )
construct would work for you.
... or you could use a dictionary if you're comfortable with that.
Depending on the source of the string you may be advised to change the case to a consistant format ....
Regards
dgorsman
Message 7 of 10 (1,089 Views)
03-08-2012 10:33 AM in reply to: KerryBrown
Or a (switch...), since color values are mutually exclusive.  The various case statements would associate the strings with the enumerated values, or ACI values.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Valued Mentor
KerryBrown
Message 8 of 10 (1,077 Views)
03-08-2012 04:26 PM in reply to: chockalingam
One option:
Code solution is posted at  http://www.theswamp.org/index.php?topic=41172.msg463389#msg463389
// (C) CodeHimBelonga kdub
using System;
using System.Windows;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using StringToColorTest;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof (StringToColor))]
namespace StringToColorTest
    public class StringToColor
        [CommandMethod("DoIt")]
        public void StringToColorTest_01()
            Editor ed           = AcadApp.DocumentManager.MdiActiveDocument.Editor;
            string colorString  = AskUserForColorString(ed);
            int colorIndex      = ColorIndexFromString(colorString);
            MessageBox.Show( "Color String : " +
                                        colorString +
                                        "\nTranslates to Integer : " +
                                        colorIndex.ToString(),
                              "StringToColorTest_01");
        public string AskUserForColorString(Editor ed)
            PromptStringOptions strOpts = new PromptStringOptions("\nEnter Color: ");
            strOpts.AllowSpaces         = false;
            PromptResult res            = ed.GetString(strOpts);
            if (res.Status != PromptStatus.OK)
                return "ByLayer";
            return res.StringResult;
        public int ColorIndexFromString(string colorString)
            int result = -1;
            if (int.TryParse(colorString, out result))
                result = ((result >= 0) && (result <= 256) ? result : 256);
            else
                try
                    MyColors colorIndex =
                        (MyColors) Enum.Parse(typeof (MyColors), colorString, true);
                    if (Enum.IsDefined(typeof(MyColors), colorIndex))
                        result = (int) colorIndex;
                catch (ArgumentException)
                    AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(
        "Blooper !!");
                    return 256;
            return result;
        private enum MyColors
            ByBlock = 0,
            Red     = 1,
            Yellow  = 2,
            Green   = 3,
            Cyan    = 4,
            Blue    = 5,
            Magenta = 6,
            White   = 7,
            Grey    = 8,
            ByLayer = 256
Valued Contributor
chockalingam
Message 9 of 10 (1,062 Views)
03-08-2012 08:03 PM in reply to: chockalingam
Thanks for solution, this code helps me................
Valued Mentor
KerryBrown
Message 10 of 10 (1,034 Views)
03-09-2012 05:49 PM in reply to: chockalingam
You're welcome.
It was an interesting technical problem.
Regards
