.NET
Valued Contributor
Ertqwa
Message 1 of 5 (273 Views)
Changing position of AttributeDefinition
273 Views, 4 Replies
12-18-2012 01:16 AM
Hello Forum,
I am trying to change the position of an AttributeDefinition in a block, but it nothing is changed:
foreach (ObjectId oidAttribute in btrBlock)
    adOrg = taTransaction.GetObject(oidAttribute, OpenMode.ForRead) as AttributeDefinition;
    if (adOrg != null)
            adOrg.UpgradeOpen();
            adOrg.Position = new Point3d(0, 0, 0);
            // Break;
            break;
    adOrg = null;
Commit();
 What is wrong? How do I change the position?
Thank you.
Valued Contributor
michael.vanhoose
Message 2 of 5 (263 Views)
Re: Changing position of AttributeDefinition
12-18-2012 03:54 AM in reply to: Ertqwa
Don't forget to go back thru the blockreferenceid's and update all the block references with the new difinition.
After you change the difinition insert a new block.  you will see the new position.  But, the old block references do not have that position.
khoa.ho
Message 3 of 5 (254 Views)
12-18-2012 06:42 AM in reply to: Ertqwa
Attribute definition and reference are derived classes of DBText, which has two parameters to define its location (Position and AlignmentPoint). The alignment of the text may need to be updated after changing its content, which relates to middle/right horizontal/vertical alignment and font style. To update the text alignment, you need to manually set AlignmentPoint property or call attributeDefinition.AdjustAlignment(HostApplicationServices.WorkingDatabase)
-Khoa
Valued Contributor
Ertqwa
Message 4 of 5 (219 Views)
12-22-2012 06:01 AM in reply to: michael.vanhoose
True, but my problem was that I had to change AlignmentPoint.
Thank you for the response.
Valued Contributor
Ertqwa
Message 5 of 5 (218 Views)
12-22-2012 06:02 AM in reply to: khoa.ho
Yes changing AlignmentPoint does the trick.
Thanks!
You are not logged in.
Ask the Community
