.NET
Changing MTextAttribute.Contents has no effect
2 REPLIES 2
axelgenus
557 Views, 2 Replies
I'm writing a program to perform massive block's attributes changes automatically. Normal attributes does change correctly setting the property AttributeReference.TextString but MTextAttributes does not work as expected: when I change AttributeReference.TextString I cannot use special characters (such as '\P' to start new lines) and if I try setting the AttributeReference.MTextAttribute.Contents property the content of the attribute does not change at all!
How can I solve the problem?
Thank you,
Alessandro.
2 REPLIES 2
FRFR1426
in reply to: axelgenus
I'm a bit late, but it may be useful to someone. Try this:
MText mText = attRef.MTextAttribute;
mText.Contents = "...";
attRef.MTextAttribute = mText;
This way, the setter of the MTextAttribute property is called and the attribute update itself. I change the width of the attribute like this and it works (but I've not tested the Contents property).
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
CADbloke
in reply to: FRFR1426
I did and this works. THANK YOU.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
”Boost
