Hello Forum,
I have code that changes the MLeaderStyle property of a MLeader object.
When I run the code, the current annotation scale is added to the MLeader and set as current. I don't want this to happen, but this happens automatically.
Any idea what could cause this?
Code:
MLeader objMLeader; DBDictionary dbdMLStyles; string strMLeaderStyleNew; ... objMLeader.UpgradeOpen(); objMLeader.MLeaderStyle = (ObjectId)dbdMLStyles[strMLeaderStyleNew]; objMLeader.DowngradeOpen();
Thank you.
Then digg dipper to this article:Thanks to Kean Walmsley
The article did not solve my problem.
Until I find out what the problem is, I will check if the current annotation scale is assigned to the object before I edit it. If not, remove it afterwards.
Ty for the reply.
