.NET
Changing Dimension style property to same value crashes AutoCAD
5 REPLIES 5
2109 Views, 5 Replies
In my code, I create a copy of dimension style:
s3 = New DimStyleTableRecord
s3.CopyFrom(vz)
s3.Name = nazov
tst.Add(s3)
_trans.AddNewlyCreatedDBObject(s3, True)
_trans.Commit()
 then, in another part of the code, I open the new style and change a property:
        Using trans As Transaction = db.TransactionManager.StartTransaction
            ds = trans.GetObject(ds.ObjectId, OpenMode.ForWrite)
            ds.Dimtxsty = s2TextStyle.ObjectId
            trans.Commit()
        End Using
this works OK for the first time, but when I run the code again, I don't create the new style, I just take the existing one and changing the Dimtxtsty property to the value it already has causes AutoCAD crash
5 REPLIES 5
sszabo
My guess would be that your object was createcd/copied in the context of a different transaction and you don't have access to it the second time around.
It would help if you recreated your problem in a self contained example (autocad command) so that people can try it themselves.  For instance I could copy your code into an existing project that installes thread/domain unhandled exception handlers and see why acad is crashing to begin with.
in reply to: sszabo
I will separate it and post later
is there a way to catch the exception before the fatal error?
I can't reproduce the problem when I separate the code, I also simulated the multithreading and call from a form, but the problem doesn't show.
I solved it by testing, if the style is already the same:
If ds.Dimtxsty <> s2TextStyle.ObjectId Then ds.Dimtxsty = s2TextStyle.ObjectId
sszabo
Ok, I am glad you solved it.
I usually inherit from control and install handlers for AppDomain.CurrentDomain.FirstChanceException and AppDomain.CurrentDomain.UnhandledException in the Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize routine.  Note that you will have to use some logging system that's independent of autocad (I'm using Nlog) and it's not going to work 100% of the time but it will catch most of your mistakes and some of autodesk's.  I might cook up an example and post it in a few days.
in reply to: sszabo
I was experimenting with this, I had handler hooked on those events, but it didn't help, because I didn't go as far as you  with the logging system so fatal errors still produced no information.
That example would be really helpful for many people, because you can mess up in so many ways and the result is always the same - fatal error.
”Boost
