Changing Dimension Styles While Adding Dimensions
mgorecki
mgorecki
 In an earlier part of my code, I read in the dimension styles from another drawing.  Now I would like to start adding dimensions.  I have one style that has "Boxed" dimension text.  I have another that is just a basic dimension style.  I would like to know how to make a dimension style current.  I've looked at setting the DimensionStyleName to the name I want, but it errors out, so I'm not doing something right.
Any Help on this would be greatly appreciated.
Mark
mgorecki
By the way, I'm using VB.Net.
Hallex
take a look at this post
http://forums.autodesk.com/t5/NET/Set-current-textstyle/m-p/2485015/highlight/true#M14423
see code at the bottom of page, published by Irvin
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Post the code you have that errors out. Maybe someone can take it from there.
mgorecki
Hi Hallex,
Thanks for the link.  I think I have it figured out.  This code works for me.
    Public Sub AddHorDim(ByVal dimPnt1 As Point3d, ByVal dimPnt2 As Point3d, ByVal dimLoc As Point3d, ByVal dimType As String)
        'Get the current database
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Dim DimStyleName As String
        DimStyleName = "BASIC"
        Select Case dimType
            Case "A"
            Case "B"
                DimStyleName = "BASIC_1pl_decimal"
            Case "C"
                DimStyleName = "BASIC_BOXED"
            Case "D"
                DimStyleName = "BASIC_PAREN"
        End Select
        'Start a transaction
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            Dim acDimStylTbl As DimStyleTable = acTrans.GetObject(acCurDb.DimStyleTableId, OpenMode.ForRead)
            'Open the Block table for read
            Dim acDimStylTblRec As DimStyleTableRecord
            acDimStylTblRec = New DimStyleTableRecord()
            acDimStylTblRec.Name = DimStyleName
            acDimStylTblRec = acTrans.GetObject(acDimStylTbl(DimStyleName), OpenMode.ForWrite)
            acCurDb.Dimstyle = acDimStylTbl(DimStyleName)
            acCurDb.Dimstyle = acDimStylTblRec.ObjectId
            acCurDb.SetDimstyleData(acDimStylTblRec)
            'Commit the changes
            acTrans.Commit()
        End Using
        '' Start a transaction
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
            'Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            'Create the rotated dimension
            'To add a horizontal dimension, use a rotation angle of 0.0
            Dim acRotDim As RotatedDimension = New RotatedDimension()
            acRotDim.SetDatabaseDefaults()
            acRotDim.XLine1Point = dimPnt1
            acRotDim.XLine2Point = dimPnt2
            acRotDim.DimLinePoint = dimLoc
            'Rotation angle is in radians
            acRotDim.Rotation = 0.0
            'Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acRotDim)
            acTrans.AddNewlyCreatedDBObject(acRotDim, True)
            'Commit the changes
            acTrans.Commit()
        End Using
    End Sub
Hallex
You're quite welcome,
it's not my code though
Thanks Irvin 🙂
