.NET
Valued Contributor
dynamicscope
Message 1 of 4 (407 Views)
Changing Current Layout and Plot Page Setup Programatically
407 Views, 3 Replies
07-09-2013 11:05 PM
After I failed to implement auto-batch-plotting(printing), I decided to do it semi-automatically.
I am going to open each drawing and change the current layout to paperspace1 and set the plot page settings, and then close and save the document.
So now, my problem is chainging current layout of the opened document and manipulating plot page settings.
Even a little hint or sample code snippet would be very appreciated. =)
FYI, I am currently using Object ARX 2007 with C#.
Best regards,
Jake
Valued Mentor
fieldguy
Message 2 of 4 (387 Views)
Re: Changing Current Layout and Plot Page Setup Programatically
07-10-2013 07:17 AM in reply to: dynamicscope
There is plenty of code here for changing layouts.  Try keyword search "layoutname".
There is some vb code here http://forums.autodesk.com/t5/NET/Layouts-and-Viewports/td-p/3128748
Valued Contributor
dynamicscope
Message 3 of 4 (359 Views)
07-11-2013 05:26 AM in reply to: fieldguy
Awesome~!!
Document doc = Application.DocumentManager.Add("acad");
DocumentLock docLock = doc.LockDocument();
Database db = doc.Database;
using (Transaction tr = db.TransactionManager.StartTransaction())
	LayoutManager lm = LayoutManager.Current;
	Layout layoutObj;
	DBDictionary layoutDict;
	using (layoutDict = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead) as DBDictionary)
		foreach (System.Collections.DictionaryEntry de in layoutDict)
			using (layoutObj = tr.GetObject((ObjectId)(de.Value), OpenMode.ForRead) as Layout)
				lm.CurrentLayout = layoutObj.LayoutName;
	tr.Commit();
One down!!
Now, I need to figure out how to change the page setup programmatically, so I can batch print multiple drawings at once!!!
Valued Mentor
fieldguy
Message 4 of 4 (355 Views)
07-11-2013 07:14 AM in reply to: dynamicscope
Glad you found it.  IMO Kean Walmsley has the best examples for plotting - this is 1 of them
http://through-the-interface.typepad.com/through_the_interface/2007/10/previewing-an-1.html
Search plotting at that site for others - they are c# for the most part.
You are not logged in.
Ask the Community
