.NET
Valued Contributor
dynamicscope
Message 1 of 9 (604 Views)
Changing 3D View to Top View
604 Views, 8 Replies
08-02-2013 02:39 AM
doc.SendStringToExecute("-view\ntop\n", true, false, false);
Well, I know this would change the view.
But I need to do this in the middle of some process. (I tried it, but the next step gets executed before view change is done.)
I am changing the view to use SelectWindowPolygon().
So I need to do this by lines of codes. (So that the view change gets done before the next step.)
I found a couple solutions but the codes contain some methods that is not supported in ARX 2007.
If anyone can give me something I can start with, it would be very appreciated.
FYI, I am using ARX 2007 with C#
ADN Support Specialist
fenton.webb
Message 2 of 9 (574 Views)
Re: Changing 3D View to Top View
08-05-2013 02:50 PM in reply to: dynamicscope
Did you see this http://through-the-interface.typepad.com/through_the_interface/2009/02/smoothly-transitioning-betwee...
Fenton Webb
Developer Technical Services
Autodesk Developer Network
Valued Contributor
dynamicscope
Message 3 of 9 (541 Views)
08-12-2013 04:44 AM in reply to: fenton.webb
Yes, I looked at it. It looks little complicated.
I just hoped if there is any easier way to do it. (Since there is a command to do it.)
But I guess it is worth trying...
:smileyhappy:
fenton.webb
Message 4 of 9 (530 Views)
08-12-2013 08:37 AM in reply to: dynamicscope
Yes, there is a command to do it however the smooth view scrolling is disabled in that command if invoked from a script, so it's not so nice :-(
Fenton Webb
Valued Contributor
dynamicscope
Message 5 of 9 (512 Views)
08-13-2013 02:59 AM in reply to: fenton.webb
Actually, I do not quite need the animation effect.
I need to change the view to use Editor.SelectWindowPolygon()
Well, I came up with this~~
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Manager gsm = doc.GraphicsManager;
int vp = Convert.ToInt32(Application.GetSystemVariable("CVPORT"));
using (View view = gsm.GetGsView(vp, true))
	ViewTableRecord v = new ViewTableRecord();
	v.SetUcs(view.Position, Vector3d.XAxis, Vector3d.YAxis);
	ed.SetCurrentView(v);
This quite "LOOKS" acting right, but the result is weird.
If I use Editor.SelectWindowPolygon() (with the same polygon), it catches different objects (compared to the result I get by entering "-view top ", then run the Editor.SelectWindowsPolygon() ).
I need to check why this is happening.
If anyone knows the reason, any comment would be appreciated.
_gile
Message 6 of 9 (496 Views)
08-13-2013 10:52 AM in reply to: dynamicscope
You can synchrously call  the VIEW command P/Invoking acedCmd or using the Tony Tanzillo's wrapper for non-public Editor.RunCommand() method.
You can also use the following method.
        private void SetViewTop()
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Extents3d extents = db.TileMode ?
                new Extents3d(db.Extmin, db.Extmax) :
                (short)Application.GetSystemVariable("CVPORT") == 1 ?
                    new Extents3d(db.Pextmin, db.Pextmax) :
                    new Extents3d(db.Extmin, db.Extmax);
            using (Transaction tr = db.TransactionManager.StartTransaction())
            using (ViewTableRecord view = ed.GetCurrentView())
                Matrix3d WCS2DCS =
                    Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
                    Matrix3d.Displacement(view.Target - Point3d.Origin);
                extents.TransformBy(WCS2DCS.Inverse());
                view.ViewDirection = Vector3d.ZAxis;
                view.Width = extents.MaxPoint.X - extents.MinPoint.X;
                view.Height = extents.MaxPoint.Y - extents.MinPoint.Y;
                view.CenterPoint = new Point2d(
                    (extents.MinPoint.X + extents.MaxPoint.X) / 2.0,
                    (extents.MinPoint.Y + extents.MaxPoint.Y) / 2.0);
                ed.SetCurrentView(view);
                tr.Commit();
Gilles Chanteau
_gile
Message 7 of 9 (477 Views)
08-14-2013 11:57 AM in reply to: _gile
I'am glad you solve your probem.
Here's a more generic method to set any orthogonal and isometric view and some commands to set these views from the numpad.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(ViewSample.CommandMethods))]
namespace ViewSample
    public class CommandMethods
        enum ViewDirection { Top, Bottom, Front, Back, Left, Right, SeIso, SwIso, NeIso, NwIso }
        private void SetView(ViewDirection vDir)
            Vector3d viewDir = new Vector3d();
            switch (vDir)
                case ViewDirection.Top:
                    viewDir = Vector3d.ZAxis; break;
                case ViewDirection.Bottom:
                    viewDir = Vector3d.ZAxis.Negate(); break;
                case ViewDirection.Front:
                    viewDir = Vector3d.YAxis.Negate(); break;
                case ViewDirection.Back:
                    viewDir = Vector3d.YAxis; break;
                case ViewDirection.Left:
                    viewDir = Vector3d.XAxis.Negate(); break;
                case ViewDirection.Right:
                    viewDir = Vector3d.XAxis; break;
                case ViewDirection.SeIso:
                    viewDir = new Vector3d(1.0, -1.0, 1.0); break;
                case ViewDirection.SwIso:
                    viewDir = new Vector3d(-1.0, -1.0, 1.0); break;
                case ViewDirection.NeIso:
                    viewDir = new Vector3d(1.0, 1.0, 1.0); break;
                case ViewDirection.NwIso:
                    viewDir = new Vector3d(-1.0, 1.0, 1.0); break;
db.updateext(true); Extents3d extents = db.TileMode ? new Extents3d(db.Extmin, db.Extmax) : (int)Application.GetSystemVariable("CVPORT") == 1 ? new Extents3d(db.Pextmin, db.Pextmax) : new Extents3d(db.Extmin, db.Extmax); using (Transaction tr = db.TransactionManager.StartTransaction()) using (ViewTableRecord view = ed.GetCurrentView()) { Matrix3d viewTransform = Matrix3d.PlaneToWorld(viewDir) .PreMultiplyBy(Matrix3d.Displacement(view.Target - Point3d.Origin)) .PreMultiplyBy(Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target)) .Inverse(); extents.TransformBy(viewTransform); view.ViewDirection = viewDir; view.Width = (extents.MaxPoint.X - extents.MinPoint.X) * 1.2; view.Height = (extents.MaxPoint.Y - extents.MinPoint.Y) * 1.2; view.CenterPoint = new Point2d( (extents.MinPoint.X + extents.MaxPoint.X) / 2.0, (extents.MinPoint.Y + extents.MaxPoint.Y) / 2.0); ed.SetCurrentView(view); tr.Commit(); } } [CommandMethod("0")] public void ViewBottom() { SetView(ViewDirection.Bottom); } [CommandMethod("1")] public void ViewSouthWestIso() { SetView(ViewDirection.SwIso); } [CommandMethod("2")] public void ViewFront() { SetView(ViewDirection.Front); } [CommandMethod("3")] public void ViewSeIso() { SetView(ViewDirection.SeIso); } [CommandMethod("4")] public void ViewLeft() { SetView(ViewDirection.Left); } [CommandMethod("5")] public void ViewTop() { SetView(ViewDirection.Top); } [CommandMethod("6")] public void ViewSouthEastIso() { SetView(ViewDirection.Right); } [CommandMethod("7")] public void ViewNorthWestIso() { SetView(ViewDirection.NwIso); } [CommandMethod("8")] public void ViewBack() { SetView(ViewDirection.Back); } [CommandMethod("9")] public void ViewNorthEastIso() { SetView(ViewDirection.NeIso); } } }
Gilles Chanteau
Valued Contributor
jaboone
Message 8 of 9 (469 Views)
08-14-2013 12:35 PM in reply to: _gile
There is one command I use all the time to out of 3d and back to my current usc, or back to original world.  This always puts me back on track.
PLAN
Learning as I go
Active Member
Skarafaz
Message 9 of 9 (383 Views)
09-16-2013 02:36 AM in reply to: jaboone
Hi! I found the code posted by _gile very interesting; is there a way to set these fixed views on an offscreen device? Device.Add() accepts GraphicsSystem.View objects that are quite different from ViewTableRecord objects so I can't understand how to do the same calculations.
You are not logged in.
Ask the Community
