.NET
Valued Contributor
e.g.
Message 1 of 4 (239 Views)
Change the current space
239 Views, 3 Replies
07-11-2011 04:01 PM
Hello everybody,
I have a small application that zooms on an entity with specific properties. The problem is that if I am in paperspace and the entity is in model space, i cannot see the entity. How can I make the entity's space to become the current space?
e.g.
_gile
Message 2 of 4 (224 Views)
Re : Change the current space
07-12-2011 01:01 AM in reply to: e.g.
You can use the read/write CTAB sysvar.
Gilles Chanteau
Distinguished Mentor
michael.robertson
Message 3 of 4 (203 Views)
Re: Change the current space
07-12-2011 07:49 AM in reply to: e.g.
If you know the name of the layout you can use
LayoutManager.Current.CurrentLayout = layoutName
If you don't know the layout of the entity you can use:
    Public Shared Function GetLayoutName(ByVal ent As Entity) As String
        Dim blockId As ObjectId = ent.BlockId
        Dim btr As BlockTableRecord = TryCast(ent.BlockId.GetObject(OpenMode.ForRead), BlockTableRecord)
        If Not btr.LayoutId.IsNull Then
            Dim layout As Layout = TryCast(btr.LayoutId.GetObject(OpenMode.ForRead), Layout)
            Return layout.LayoutName
        End If
        Return String.Empty
    End Function
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Valued Contributor
e.g.
Message 4 of 4 (190 Views)
07-12-2011 10:13 AM in reply to: michael.robertson
Thank you very much, it did help.
e.g.
You are not logged in.
Ask the Community
