.NET
Change font in tooltip text.
2 REPLIES 2
Keith.Brown
636 Views, 2 Replies
Does anyone know of a method to change the font inside the the tooltips generated when you hover over an object?? I have followed the tutorials from the developers specifically lab 6 which uses the point monitor event to append text to the tooltips when the aperture is hovering over an item in autocad. I would like to be able to make certain words bold but so far have not figured out how to do so. Any help would be appreciated. Thanks in advance.
2 REPLIES 2
fieldguy
in reply to: Keith.Brown
According to >>this<< you need to create your own Tooltip class and a draw event.  I would like to see this if you decide to do it.
cincir
in reply to: fieldguy
But is there any chance to register your ToolTipDraw class to autocad for using it instead of itselfs.
”Boost
