.NET
Change entity color & linetype problem.
6 REPLIES 6
sgsawdy
2386 Views, 6 Replies
I am using ACADE 2008 and VB.NET. I have a multitude of drawings that I am doing the same three and four operations on and would like to write VB.NET program to do it. I can get my selections set just fine, but my first problem is figuring out how to change all drawing entities color and linetype to "ByLayer". So far I have not gotten past changing just the color value. I have tried multiple variations on the following line without success:
myAcadEnt.Color = Colors.Color.FromDictionaryName("ByLayer")
Can anybody get me pointed in the right direction? I am grateful for any help.
Scott
6 REPLIES 6
NathTay
in reply to: sgsawdy
myAcadEnt.ColorIndex = 256
Dale.Bartlett
Is there a similar value for the LinetypeId as for layers to reset to BYLAYER?
ent.ColorIndex = 256; /BYLAYER
// ent.LinetypeId = ???; //BYLAYER
rather than doing this:
ent.Linetype = "BYLAYER";
Dale
______________
Yes, I'm Satoshi.
Balaji_Ram
in reply to: Dale.Bartlett
Hello Dale,
"Database.ByLayerLineType" property will give you the ObjectId of the "ByLayer" line type.
Balaji
Developer Technical Services
Autodesk Developer Network
Dale.Bartlett
That's correct. But what I want to know is what is the LinetypeID eqivalent of "BYLAYER"?. Thanks for hte reply, Dale
______________
Yes, I'm Satoshi.
fieldguy
Something like this -
ent.linetype = db.ByLayerLinetype
Balaji told you - it is returned by the property he mentioned, and it must be assigned to the entity's LinetypeId property (as opposed to the Linetype property)
”Boost
