.NET
Change block layer after insertio
3 REPLIES 3
581 Views, 3 Replies
Hi:
I've inserted a block into my drawing with this code:
Dim tmpDb As New Database(False, True)
        tmpDb.ReadDwgFile(nombrebloque, System.IO.FileShare.Read, True, "")
        Dim Transform As Matrix3d = Matrix3d _
                                    .Scaling(scale, Point3d.Origin) _
                                    .PreMultiplyBy(Matrix3d.Displacement(DispacementVector)) _
                                    .PreMultiplyBy(myed.CurrentUserCoordinateSystem)
        mydb.Insert(Transform, tmpDb, True)
and I would like to change some properties (layer, color,...) of the entities. (without modify the original block)
How can I access to these entities?
thanks..
3 REPLIES 3
Hallex
Try this code, just change the path of your source drawing in the code
(assume your drawing is contains just separate objects like attribues, lines,and other
entities but not complete block itself)
        <CommandMethod("nombreblk", CommandFlags.Session And CommandFlags.Redraw)> _
        Public Sub testExternalInsert()
            Try
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim myed As Editor = doc.Editor
                Dim mydb As Database = doc.Database
                Dim sourceFileName As String = "C:\Test\NombreBloque.dwg"	'<-- source file path
                Dim blkId As ObjectId = ObjectId.Null
                Dim nombrebloque As String = SymbolUtilityServices.GetBlockNameFromInsertPathName(sourceFileName)
                Using docloc As DocumentLock = doc.LockDocument
                    Using tr As Transaction = doc.TransactionManager.StartTransaction
                        Dim blkTbl As BlockTable = tr.GetObject(mydb.BlockTableId, OpenMode.ForRead, False, True)
                        If blkTbl.Has(nombrebloque) Then
                            Application.ShowAlertDialog("Block " + nombrebloque + " already exist. Exit.")
                            Return
                        End If
                        Dim myBtr As BlockTableRecord = TryCast(tr.GetObject(mydb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                        Using tmpDb As New Database(True, True)
                            tmpDb.ReadDwgFile(sourceFileName, System.IO.FileShare.Read, False, "")
                            blkId = mydb.Insert(nombrebloque, tmpDb, True)
                            tmpDb.CloseInput(True)
                        End Using
                        If Not blkTbl.Has(nombrebloque) Then
                            Application.ShowAlertDialog("Problem with import block. Exit")
                            Return
                        End If
                        Dim btr As BlockTableRecord = DirectCast(tr.GetObject(mydb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                        Dim bref As BlockReference = New BlockReference(Point3d.Origin, blkId)
                        'change some properties:
                        Dim scale As Double = 1.0
                        Dim scl As Scale3d = New Scale3d(scale)
                        bref.ScaleFactors = scl
                        bref.Rotation = Math.PI / 4
                        bref.LayerId = mydb.Clayer
                        bref.Color = mydb.Cecolor
                        myBtr.AppendEntity(bref)
                        tr.AddNewlyCreatedDBObject(bref, True)
                        Dim blkRec As BlockTableRecord = DirectCast(tr.GetObject(blkTbl(nombrebloque), OpenMode.ForRead, False, True), BlockTableRecord)
                        If blkRec.HasAttributeDefinitions Then
                            Dim attColl As AttributeCollection = bref.AttributeCollection
                            For Each attId As ObjectId In blkRec
                                Dim ent As Entity = DirectCast(tr.GetObject(attId, OpenMode.ForRead), Entity)
                                If TypeOf ent Is AttributeDefinition Then
                                    Dim attDef As AttributeDefinition = DirectCast(ent, AttributeDefinition)
                                    Dim attRef As New AttributeReference()
                                    attRef.SetAttributeFromBlock(attDef, bref.BlockTransform)
                                    attRef.Tag = attDef.Tag
                                    attRef.TextString = attDef.TextString
                                    Dim id As ObjectId = attColl.AppendAttribute(attRef)
                                    attRef.AdjustAlignment(mydb)
                                    tr.AddNewlyCreatedDBObject(attRef, True)
                                End If
                            Next
                        End If
                        tr.Commit()
                    End Using
                End Using
            Catch ex As System.Exception
                Application.ShowAlertDialog(ex.Message.ToString() & vbLf & ex.StackTrace)
            Finally
                Application.ShowAlertDialog("See result.")
            End Try
        End Sub
in reply to: Hallex
great! it runs!
thanks
Hallex
Im happy to help
Cheers Smiley Happy
”Boost
