Change attribute properties inside a multileader
andre_adc-dao
andre_adc-dao
Is anybody have a sample code to change attributes properties when the block is inside a multileader?
Regards
André
Hallex
Hi André, Take a look at this example probably it will helps
http://www.acadnetwork.com/topic-210.msg381.html#msg381
Hallex
Here is VB.NET code
        ' Make sure if block "LEADERBLOCK" is exist
        ' and have 2 attributes "NUMBER" & "DESCRIPTION"
        ' Or change all above to your needs
        ' based on article from
        ' http://adndevblog.typepad.com/autocad/2012/05/how-to-create-mleader-objects-in-net.html
        <CommandMethod("MBA")> _
        Public Shared Sub netBlockMLeader()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = TryCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                Dim btr As BlockTableRecord = TryCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                ' Make sure if this block exist
                If Not bt.Has("LEADERBLOCK") Then
                    ed.WriteMessage(vbLf & "You need to define a ""LEADERBLOCK"" first...")
                    Return
                End If
                Dim ppo As New PromptPointOptions(vbLf & "Pick arrow point >>")
                Dim ptres As PromptPointResult
                ptres = ed.GetPoint(ppo)
                If ptres.Status <> PromptStatus.OK Then
                    Return
                End If
                Dim arrPt As Point3d = ptres.Value
                ppo = New PromptPointOptions(vbLf & "Pick leader text point >>")
                ppo.UseBasePoint = True
                ppo.BasePoint = arrPt
                ppo.UseDashedLine = True
                    Return
                End If
                Dim textPt As Point3d = ptres.Value
                Dim firsttxt As String
                Dim pso As New PromptStringOptions(vbLf & "Enter text for attribute NUMBER: ")
                pso.AllowSpaces = True
                Dim res As PromptResult
                res = ed.GetString(pso)
                If res.Status <> PromptStatus.OK Then
                    Return
                End If
                firsttxt = res.StringResult
                Dim sndtxt As String
                pso.Message = vbLf & "Enter text for attribute DESCRIPTION: "
                    Return
                End If
                sndtxt = res.StringResult
                Dim mlead As New MLeader()
                mlead.SetDatabaseDefaults()
                mlead.ContentType = ContentType.BlockContent
                ' Get ObjectId of mleader block
                mlead.BlockContentId = bt("LEADERBLOCK")
                mlead.BlockPosition = textPt
                Dim idx As Integer = mlead.AddLeaderLine(arrPt)
                mlead.AddFirstVertex(0, arrPt)
                'Handle Block Attributes
                Dim num As Integer = 0
                Dim leadblk As BlockTableRecord = TryCast(tr.GetObject(mlead.BlockContentId, OpenMode.ForRead), BlockTableRecord)
                'Doesn't take in consideration oLeader.BlockRotation
                Dim mat As Matrix3d = Matrix3d.Displacement(mlead.BlockPosition.GetAsVector())
                For Each attId As ObjectId In leadblk
                    Dim attdef As AttributeDefinition = TryCast(tr.GetObject(attId, OpenMode.ForRead), AttributeDefinition)
                    If attdef IsNot Nothing Then
                        Dim tag As String = attdef.Tag.ToUpper
                        Dim attref As New AttributeReference()
                        Select Case tag
                            Case "NUMBER"
                                attref.SetAttributeFromBlock(attdef, mat)
                                attref.Position = attdef.Position.TransformBy(mat)
                                attref.TextString = firsttxt
                                mlead.SetBlockAttribute(attId, attref)
                            Case "DESCRIPTION"
                                attref.TextString = sndtxt
                                'Case ETC ETC.....
                        End Select
                    End If
                Next
                btr.AppendEntity(mlead)
                tr.AddNewlyCreatedDBObject(mlead, True)
                tr.Commit()
            End Using
        End Sub
andre_adc-dao
Thank you, I will take a look at your sample code in the next days and give you a feddback.
André
