Show only
Search instead for
I have read through other threads pertaining to changing the PathName of an xref in a drawing ( http://discussion.autodesk.com/forums/thread.jspa?messageID=6327420豼 is an example). If I change the pathname, save, close, and reopen the drawing, then the results are as expected.
How can I force AutoCAD to update/reload the xref after I change the path without having to save, close, and reopen?
