.NET
Valued Contributor
Message 1 of 13 (416 Views)
Accepted Solution
Change Color, Line Type and Line weight without selecting any objects
416 Views, 12 Replies
03-09-2012 07:57 PM
I am trying to Change the Color, Line Type and Line weight in Properties Pallete without selecting any objects, but i don't know how to do this.
*Expert Elite*
Jeff_M
Message 2 of 13 (378 Views)
Re: Change Color, Line Type and Line weight without selecting any objects
03-09-2012 10:00 PM in reply to: chockalingam
Those are controlled by the drawing's Current sysvars.
CECOLOR
CELTYPE
CELWEIGHT
Jeff_M, also a frequent Swamper
Valued Contributor
Message 3 of 13 (374 Views)
03-09-2012 10:06 PM in reply to: chockalingam
Can you guide me, to use this in .net code
Valued Mentor
KerryBrown
Message 4 of 13 (366 Views)
03-09-2012 10:14 PM in reply to: chockalingam
Untested
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
// AcadApp.SetSystemVariable(string name, object value)
	AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")
	AcadApp.SetSystemVariable("CELTYPE", "ByLayer")
	AcadApp.SetSystemVariable("CELWEIGHT", -1)
 Regards
class keyThumper<T> : Lazy<T>;      another  Swamper
Valued Contributor
Message 5 of 13 (363 Views)
03-09-2012 10:28 PM in reply to: chockalingam
On using the above code,
AcadApp.SetSystemVariable("CECOLOR", "BYLAYER")- Results No Change
AcadApp.SetSystemVariable("CELTYPE", "ByLayer")- Results in "eInvalidInput" error
AcadApp.SetSystemVariable("CELWEIGHT", -1)- Results in "eInvalidInput" error
Valued Mentor
KerryBrown
Message 6 of 13 (352 Views)
03-09-2012 10:55 PM in reply to: chockalingam
Works for me. ... see attached piccy.
Valued Contributor
Message 7 of 13 (347 Views)
03-09-2012 11:01 PM in reply to: chockalingam
I don't know why it is not working for me.....
But i got the solution in another way, my solution code follows,
Using lock As DocumentLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Using acTrans As Transaction = acDoc.Database.TransactionManager.StartTransaction()
acDoc.Database.Celweight = LineWeight.LineWeight015
acDoc.Database.Cecolor = Autodesk.AutoCAD.Colors.Color.FromColor(Color.Red)
Dim acLineTypTbl As LinetypeTable
acLineTypTbl = acTrans.GetObject(acDoc.Database.LinetypeTableId, OpenMode.ForRead)
Dim sLineTypName As String = "Continuous"
If acLineTypTbl.Has(sLineTypName) = True Then
'' Set the linetype Center current
acDoc.Database.Celtype = acLineTypTbl(sLineTypName)
'' Save the changes
acTrans.Commit()
End Using
End Using
Valued Contributor
Message 8 of 13 (341 Views)
03-09-2012 11:15 PM in reply to: chockalingam
But the Only Issue in above code is we can't reback to "ByLayer"
Valued Mentor
KerryBrown
Message 9 of 13 (335 Views)
03-09-2012 11:35 PM in reply to: chockalingam
Please clarify your last post. ??
And the code you posted is different to your initial question  ... but I see how I could confuse your intent.
*Expert Elite*
Alfred.NESWADBA
Message 10 of 13 (331 Views)
03-09-2012 11:47 PM in reply to: chockalingam
Why not, this code does not Work?
acDoc.Database.Celtype = "byLayer"
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
